ejw71 Posted October 26, 2003 Share Posted October 26, 2003 Can mechanical windows be substituted for power windowed doors without modifications? Thanks, Ed Link to comment Share on other sites More sharing options...
Chris Posted October 26, 2003 Share Posted October 26, 2003 Not sure what you mean by "modifications" But: You will need to drill both the doors and cowl for the wiring. This will require removal of the doors. You may also need to drill the doors in order to mount the motor/regulator. It's been awhile since I did it so I can't remember. Either way it wasn't a big deal when I did the conversion. Chris Link to comment Share on other sites More sharing options...
wallaby Posted October 27, 2003 Share Posted October 27, 2003 Sounds to me like he's trying to go the other way. Link to comment Share on other sites More sharing options...
monte70car Posted October 27, 2003 Share Posted October 27, 2003 the only thing u will need is sheet metal to fill in the hole where the power window wires run in other then that it will fit in with not problem. unbolt the power ulit and pop it out the track and bolt the mechanical window in the same hole. robert Link to comment Share on other sites More sharing options...
Daryl Smith Posted October 27, 2003 Share Posted October 27, 2003 I did this on my 70. Not a problem. Robert is correct about the plate. Link to comment Share on other sites More sharing options...
ejw71 Posted October 27, 2003 Author Share Posted October 27, 2003 Thanks guys for the info. Understand need of a metal cover for the hole used for power window wiring. Ed Link to comment Share on other sites More sharing options...
