Guest Posted March 5, 2004 Share Posted March 5, 2004 I have been trying to id my rear end all that there is is a casting 9799100 How do you determin the gear ratio 1970 monte 350. Quote Link to comment Share on other sites More sharing options...
RichG Posted March 5, 2004 Share Posted March 5, 2004 There is an excellent article on how to ID your differential in the Technical Info link, under the Monte Carlo Archives heading. Quote Link to comment Share on other sites More sharing options...
alex's72fgmc Posted March 7, 2004 Share Posted March 7, 2004 hi there, you will need to look at the front passenger side of the rear end about 4-8 inches from the pumpkin. just clean off that area and you will find it then just look at the rear axle decode in the technical section that i wrote up. later alex Quote Link to comment Share on other sites More sharing options...
edlipman Posted March 8, 2004 Share Posted March 8, 2004 Hi: If that is the casting number the it should have the sides of the cover scalloped out. If this is the case the rear has 2:73 gears in it. It looks like an old GTO rear, because that is a Pontiac casting number. Your car also has only a 2 bbl carb on it originally too. Hope this helps Ed Quote Link to comment Share on other sites More sharing options...
Guest Posted March 9, 2004 Share Posted March 9, 2004 I've attached a photo of my rear end stamping. Its a 71 and a 2:73 non posi. If the pic is too small look in my album in the FGMCC photos in MSN. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 9, 2004 Share Posted March 9, 2004 Ok I cant do pictures undoughtably! Try this link and one of the few pictures in my album is the stamping off of my 71. http://groups.msn.com/FGMCCPhotos/cchevrolet.msnw?Page=Last Quote Link to comment Share on other sites More sharing options...
edlipman Posted March 9, 2004 Share Posted March 9, 2004 Hey cchev: Your rear end codes out as a, KD, 2:73 ratio open rear, C, Chev manufacture 196 day of year and ,B, shift. All of this info courtesy of "Chevrolet by the Numbers" by Alan Colvin. Hope this helps. Ed Quote Link to comment Share on other sites More sharing options...
alex's72fgmc Posted March 10, 2004 Share Posted March 10, 2004 kd = 2.73:1 c = Buffalo rear axle plant 196 = julian date b = "supposed to be a number possibly a 3 is what the person thought he had" 3 = 3rd shift but might be second shift "this is new" as per the assembly manual alex Quote Link to comment Share on other sites More sharing options...
Guest Posted March 11, 2004 Share Posted March 11, 2004 So you think the guy a the rear end plant accidently used a B instead of a 3, very possible. Thanks Guys! Quote Link to comment Share on other sites More sharing options...
alex's72fgmc Posted March 12, 2004 Share Posted March 12, 2004 might be but mine was made at the same plant with a number for the shift code so it is possible. Quote Link to comment Share on other sites More sharing options...
