NewTimer Posted August 19, 2013 Share Posted August 19, 2013 So I have been looking at replacing my fuel pump and have came across most aftermarket ones only come with what I am am assuming is an inlet from the gas tank and outlet that feeds to the carb. Our stock pumps have a third which I think is a return line or maybe a vapor return. What would have to be done to to switch to the two port fuel pump from our stock. Would capping the return at the gas tank be fine? Main reason of wanting to do this, is to avoid clearance issues with March Pulleys which has a mid mount compressor Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 19, 2013 Share Posted August 19, 2013 you can buy a correct pump, or just plug the smaller line which is a return line Quote Link to comment Share on other sites More sharing options...
footballubet Posted August 19, 2013 Share Posted August 19, 2013 When I replaced all my lines I eliminated the return line. Just make sure you plug it real good. Quote Link to comment Share on other sites More sharing options...
NewTimer Posted August 21, 2013 Author Share Posted August 21, 2013 So when I plug the line, would I need a fuel pressure regulator? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 21, 2013 Share Posted August 21, 2013 depends on the pump you choose Quote Link to comment Share on other sites More sharing options...
NewTimer Posted August 21, 2013 Author Share Posted August 21, 2013 What factors does it depend on? I have a 80 gph mechanical pump 5.7 to 8 psi from a long time ago that I never used. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 22, 2013 Share Posted August 22, 2013 you shouldn't need one for that pump but I would use one, Holley's like 6 1/2 PSI Quote Link to comment Share on other sites More sharing options...
