72-CLASSIC_RIDE Posted August 25, 2013 Share Posted August 25, 2013 My glove box door chrome knob has been a problem for some time now. It would intermittently fall off when glove box latch snapped closed. I was able to easily locate it back on and it would stay for awhile. I discovered if holding knob when closing glove box, it would stay on every time. Well, recently it came off while holding knob closing glove box and will not stay on any longer. I examined it to see where the problem might be but unable to determine what secures knob onto glove box door latch! I saw a button on latch assembly and corresponding relief in knob that when fitted together, button matches location of relief so button sits in relief. Can this be the feature that secured knob to key latch and simple fatigue / wear lost contact? I dont see anything that appears broken, worn or damaged that may be the problem. I'm envisioning this button and corresponding relief in knob when fitted (pressed) together created the bond. Need some guidance on this!!!! I haven't done any further investigation at this point but am aware to remove key latch there is a procedure required. Need some guidance here also please. I do have another glove box door but again, does not match my glove box key and unsure if tumblers can be adjusted to fit original key. Any and all help appreciated. Doug Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 25, 2013 Share Posted August 25, 2013 you should be able to use some epoxy and glue the cover back on Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted August 25, 2013 Author Share Posted August 25, 2013 I had considered that Sam but unsure what type of epoxy would do the job and what area(s) to apply to and questioned if ultimately it would last. Any guidance? Doug Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 25, 2013 Share Posted August 25, 2013 just make sure none just in the key slot, more isn't always better, make sure it's clean, jbweld would be my choice originally the chrome cap was pressed/crimped on Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted August 26, 2013 Author Share Posted August 26, 2013 Appreciate the info Sam. I will give it a shot. Thanx, Doug Quote Link to comment Share on other sites More sharing options...
