Murphy Posted September 8, 2013 Share Posted September 8, 2013 Hey guys & gals, installing a new RetroSound radio today and realized I need a constant 12v to this unit to save memory functions & clock. Is there a place on the fuse block or do I need to go to the battery?? Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted September 8, 2013 Share Posted September 8, 2013 One of the connectors in the middle Of the fuse block should be marked "bat" maybe the top one? Put a test light on them if the lettering is worn off until you find one that's a constant source Quote Link to comment Share on other sites More sharing options...
footballubet Posted September 8, 2013 Share Posted September 8, 2013 If you don't have a spot left in your fuse block they make a metal tab you can install at a fuse and take power from there. Â Or like in the old days they would pry out the fuse, shove the wire under it and pop it back in place. Saw that many times. Quote Link to comment Share on other sites More sharing options...
Leghome Posted September 8, 2013 Share Posted September 8, 2013 When I needed a new place in my fuse block my son in-law Jamey installed a sub block which has six fuses behind the kick panel by the drivers feet. Quote Link to comment Share on other sites More sharing options...
footballubet Posted September 8, 2013 Share Posted September 8, 2013 When I needed a new place in my fuse block my son in-law Jamey installed a sub block which has six fuses behind the kick panel by the drivers feet. Â I have one of those installed also. Sure makes it nice for adding circuits. Quote Link to comment Share on other sites More sharing options...
Murphy Posted September 8, 2013 Author Share Posted September 8, 2013 Thanks guys! I was thinking about adding a sub-block also....snowball just keeps rolling! Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted September 8, 2013 Share Posted September 8, 2013 If you don't have a spot left in your fuse block they make a metal tab you can install at a fuse and take power from there. Or like in the old days they would pry out the fuse, shove the wire under it and pop it back in place. Saw that many times. Yeah, thats usually followed by wrapping the fuse in tin foil due to it constantly blowing Boy, I dont know how any of my cars never burnt up! Quote Link to comment Share on other sites More sharing options...
footballubet Posted September 8, 2013 Share Posted September 8, 2013 I think the best one I saw was a .22 long rifle bullet in place of a fuse. And yes I said bullet and not an empty casing! Quote Link to comment Share on other sites More sharing options...
Murphy Posted September 10, 2013 Author Share Posted September 10, 2013 New radio is installed along with new rear speakers. Having issue with front speakers(2) working but will most likely replace them. Are most of you happy with the windshield antenna? Had to resolder the connection at the windshield, been looking into options other than a mast style antenna cause I prefer the clean look of no antenna.......... Quote Link to comment Share on other sites More sharing options...
Leghome Posted September 10, 2013 Share Posted September 10, 2013 I have a trunk/quarter panel mounted power antenna. Love it good station pickup and is almost unseen when down. Quote Link to comment Share on other sites More sharing options...
Murphy Posted September 10, 2013 Author Share Posted September 10, 2013 How about a picture Larry, I've been wanting to see that rear trim I buffed up for you also........ Quote Link to comment Share on other sites More sharing options...
Leghome Posted September 10, 2013 Share Posted September 10, 2013 I will try and remember to get a pix tomorrow. I had to take it back to the body shop for a minor repair. A place on the right quarter panel about the size of a quarter raised up. They are going to disassemble the quarter extension and remove the rear bumper to see what is causing the problem. Nothing major but it is not right and they are fixing it. Quote Link to comment Share on other sites More sharing options...
