72-CLASSIC_RIDE Posted October 2, 2018 Share Posted October 2, 2018 Have removed most of my lower body trim and will recondition it. I still have (2) pieces attached right behind lower front fender & where door meets (One on each side)...................... Cautious putting much pressure on them as not sure how to remove. I see no screws visible & assuming it is clips hidden behind holding trim in place. How do these come off? Thanx for your reply(s) Doug Quote Link to comment Share on other sites More sharing options...
Canuck Posted October 3, 2018 Share Posted October 3, 2018 Those have a clip with a threaded rod and a nut on the unside of the fender. Accessing those nuts is the hard part. Quote Link to comment Share on other sites More sharing options...
Canuck Posted October 3, 2018 Share Posted October 3, 2018 Very similar to these on the lower left. Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted October 3, 2018 Author Share Posted October 3, 2018 Okay Aaron & thanx. Now I have a starting point. I was pretty sure I was missing something! I restored my sail panel badges and decided to go ahead and refresh the lower moldings to keep everything looking current. I was also curious what the sheet metal looked like underneath the moldings. I believe I have now inspected every nook & cranny of the ole girl While everything has been removed, going to spend some time using scratch removal compound on the paint. Just purchased a cordless orbital buffer/polisher from Ryobi and anxious to get started on that. So I plan to keep myself entertained this Winter inside the garage. See ya all in the Spring........................ Doug Quote Link to comment Share on other sites More sharing options...
1970mcss Posted October 3, 2018 Share Posted October 3, 2018 As Aaron said three nuts holding that molding on. They are a bear to get to, I screwed up a little spot on my passenger door when I didn't get then fender re-aligned. Good luck... Quote Link to comment Share on other sites More sharing options...
