70white402
Need power seat bracket layout
Does any one have a picture or diagram of where the power seat brackets mount to the floor. Manual buckets I have but need the dimensions or advice where to put brackets.  Thanks for any help.  Jeff in n.j.
Share this post
There's no way they didn't mount to the same studs the non-power seats did. If there was, there would have been a third type of floor pan.
Share this post
X2 to what Paul said. I do know that the mounting brackets are different between the manual buckets and the power buckets. The power brackets add a second bolt on the back of the seat tracks I believe. For a total of 4 per bucket.
Share this post
Believe it or not the power seats used a different floor bracket than the regular seat. First picture is the power seat second is manual
Share this post
I'm going from bench to buckets. Leo said i have to turn the brackets in towards console a bit cause the door would hit the seat.IT would stick out if i used the bench outside bracket location.
Share this post
Jeff, I suggest you bolt the weld-in plates to the inner seat feet then place the seat into the car on the existing outer studs. This will show you where to weld the plates to the floor board.
Share this post
Jeff, just recently someone asked where to mount the bucket seat mounts. 714024SPEED posted the dimensions on where they go. We recently converted a bench seat car to buckets and used the bench seat mounting along with the weld in brackets with no fitment or alignment issues.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
