70white402 Posted June 10, 2019 Share Posted June 10, 2019 Does any one have a picture or diagram of where the power seat brackets mount to the floor. Manual buckets I have but need the dimensions or advice where to put brackets. Thanks for any help. Jeff in n.j. Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted June 11, 2019 Share Posted June 11, 2019 There's no way they didn't mount to the same studs the non-power seats did. If there was, there would have been a third type of floor pan. Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted June 12, 2019 Share Posted June 12, 2019 X2 to what Paul said. I do know that the mounting brackets are different between the manual buckets and the power buckets. The power brackets add a second bolt on the back of the seat tracks I believe. For a total of 4 per bucket. Quote Link to comment Share on other sites More sharing options...
714024SPEED Posted June 12, 2019 Share Posted June 12, 2019 Believe it or not the power seats used a different floor bracket than the regular seat. First picture is the power seat second is manual Quote Link to comment Share on other sites More sharing options...
714024SPEED Posted June 12, 2019 Share Posted June 12, 2019 Sorry fist picture is manual seat second is power Quote Link to comment Share on other sites More sharing options...
70white402 Posted June 12, 2019 Author Share Posted June 12, 2019 I'm going from bench to buckets. Leo said i have to turn the brackets in towards console a bit cause the door would hit the seat.IT would stick out if i used the bench outside bracket location. Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted June 12, 2019 Share Posted June 12, 2019 Jeff, I suggest you bolt the weld-in plates to the inner seat feet then place the seat into the car on the existing outer studs. This will show you where to weld the plates to the floor board. Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted June 13, 2019 Share Posted June 13, 2019 Jeff, just recently someone asked where to mount the bucket seat mounts. 714024SPEED posted the dimensions on where they go. We recently converted a bench seat car to buckets and used the bench seat mounting along with the weld in brackets with no fitment or alignment issues. Quote Link to comment Share on other sites More sharing options...
714024SPEED Posted June 13, 2019 Share Posted June 13, 2019 Here are the dimensions we used , hopefully they may work for you Quote Link to comment Share on other sites More sharing options...
