SPLATT71MC Posted December 25, 2013 Share Posted December 25, 2013 I'm looking to go with a serpentine set up out of a late 80's early/mid 90's truck(I'm on a budget). What I'd like to know is what all is involved in integrating the smaller and relocated A/C compressor and what are some good sources on parts and pieces to do so. The bulk of the parts(brackets,pulleys,etc) will be sourced from a wrecking yard. Thanks Steve Quote Link to comment Share on other sites More sharing options...
SPLATT71MC Posted December 28, 2013 Author Share Posted December 28, 2013 Anybody? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted December 28, 2013 Share Posted December 28, 2013 well... what engine are you working with would help, and if your get the bracket set-up from a junk yard, the only thing should be wiring, AC hoses, PS hoses Quote Link to comment Share on other sites More sharing options...
SPLATT71MC Posted December 28, 2013 Author Share Posted December 28, 2013 It's going onto a 350. Is it necessary to swap out the condenser as well to clean up the hose routing? Quote Link to comment Share on other sites More sharing options...
footballubet Posted December 28, 2013 Share Posted December 28, 2013 I've seen a couple from a truck engine on a small block. You'll need the A/C lines made and I think there is an adapter for the metric to SAE fitting on the PS pump. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted December 28, 2013 Share Posted December 28, 2013 and be careful that you won't need a reverse direction waterpump too Quote Link to comment Share on other sites More sharing options...
SPLATT71MC Posted December 28, 2013 Author Share Posted December 28, 2013 I'll get a water pump for the donor vehicle to make sure there are no issues there. Oh and duh on my part I forgot to mention that the car already has A/C if that makes a difference. Quote Link to comment Share on other sites More sharing options...
footballubet Posted December 28, 2013 Share Posted December 28, 2013 I'll get a water pump for the donor vehicle to make sure there are no issues there. Oh and duh on my part I forgot to mention that the car already has A/C if that makes a difference. If you're moving the A/C compressor to the passenger side, you'll need hoses made up. Quote Link to comment Share on other sites More sharing options...
