Malyc Posted April 21, 2014 Share Posted April 21, 2014 Hey guys, been having a lot of coolant leaks cropping up, and was wondering at what point would you recommend just replacing all of the system components. Far as I know everything is original, but it's looking like the radiator is leaking in a couple of places now. Quote Link to comment Share on other sites More sharing options...
stangeba Posted April 21, 2014 Share Posted April 21, 2014 If you remove the rad, you could find a shop to re-core it and while the rad is out, replace all the hoses. I believe the lower hose has a spring inside to prevent the hose from collapsing, so look for it. Take a mirror and try to look under the water pump at the weep hole to see if it is starting to leak. Last, and hardest, the heater core. Mine went almost 40 years, no A/C. And you thought snow balls were gone! Good luck! Bruce Quote Link to comment Share on other sites More sharing options...
Malyc Posted April 21, 2014 Author Share Posted April 21, 2014 I'm in Minnesota, there's still a decent pile of snow in my front yard, so I know they're still there... How much does a shop usually charge to recore the rad? Quote Link to comment Share on other sites More sharing options...
stangeba Posted April 21, 2014 Share Posted April 21, 2014 It's been too long and I know i will be off so I won't even try. Does the rad fit and look correct? IMO I like having my OEM stuff rebuilt or repaired when ever possible. Alternator, starter, master cylinder and rad. I like to give money to the local economy and if it fit for 40+ years, it will fit after a repair. Do a search for rad shops in your area and ask around. Bruce Quote Link to comment Share on other sites More sharing options...
stangeba Posted April 21, 2014 Share Posted April 21, 2014 Oh, sorry about the snow, I drove my Monte today here in Michigan and although it was a bit cool with the windows all down, I loved it! I'm about 25 miles North of Detroit. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted April 21, 2014 Share Posted April 21, 2014 it was about $300 to re-core my original, I also had them change it from a 2 row to a 3 row Quote Link to comment Share on other sites More sharing options...
Malyc Posted April 21, 2014 Author Share Posted April 21, 2014 Yeah, had them both down when I was driving it home yesterday. Sounded great with the new exhaust I put on last weekend, until she overheated >.> Quote Link to comment Share on other sites More sharing options...
Malyc Posted April 21, 2014 Author Share Posted April 21, 2014 300 isn't too bad... Cheaper than a new one, at any rate, and I'd know it'd fit. Quote Link to comment Share on other sites More sharing options...
NewTimer Posted April 21, 2014 Share Posted April 21, 2014 I see plenty of Replacement Radiators for under 300 on Summit. Quote Link to comment Share on other sites More sharing options...
