Sam (Bones) Posted October 12, 2014 Share Posted October 12, 2014 I know we just hashed this over recently, just want to be sure, since I can't find it in the assembly manual 1970, non-AC, tach and gauge package there are 3 grounds... long one to the parking brake bracket the 2 shorter ones... one to the cluster or both of them? Quote Link to comment Share on other sites More sharing options...
Toppless72 Posted October 12, 2014 Share Posted October 12, 2014 One to Parking brake One to Headlight switch One to the back of the cluster This is from my assembly manual page 526 Inst. Pnl. Wiring Harn. "auto trans". Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 12, 2014 Author Share Posted October 12, 2014 I have the ground strap from the head light switch to the frame of the dash in addition to the 3 grounds mentioned above page 526 of the 1970 manual shows the head light washer system I have went thru every! page of the '70 manual and have only seen 2 of the grounds Quote Link to comment Share on other sites More sharing options...
stangeba Posted October 12, 2014 Share Posted October 12, 2014 My 71 no A/C with factory gauges: One to Parking brake Parking Brake Ground screw One to Headlight switch Headlight Switch One to the back of the cluster (left rear) Back of cluster Quote Link to comment Share on other sites More sharing options...
LS5 Posted October 12, 2014 Share Posted October 12, 2014 Hey Sam, The long Black one as mentioned does go to the E-brake it fishes down to the E-brake and just to the side of the fastening 3/8 bolt there is a tapped hole that will use the same screws as the dash cluster and the first ground goes there. The second ground will screw to the dash cluster with a 1/4" screw just in the curved part of the cluster under the Tach area seeing how you have Gauges as normally it would be the Gas gauge on NON gauge clusters. The Third ground will also go where the ground strap goes for the Headlight switch/ wiper bracket, its also held in with a small dash cluster screw that is silver in color rather than black and mounts on the up part of the dash housing brace that goes over the steering column. Sam if you have painted the E-brake bracket assembly and the dash housing braces make sure to remove a little of the paint or the grounds wont make a good contact thus not grounding out properly. Darren. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 12, 2014 Author Share Posted October 12, 2014 that's where I thought it went but wanted to make sure thanks Darren Quote Link to comment Share on other sites More sharing options...
