jja Posted February 10, 2015 Share Posted February 10, 2015 I am removing and replacing my fuel pump. In the process of removing it, I notice that the positive battery cable was routed directly next to, and ran close alongside the fuel pump. The cable has enough insulation so it has not been a problem with arcing. But I noticed that the cable has a clip hanging loosely around it and wondered if the middle of the positive cable should be attached to the body somewhere to keep it away from the fuel pump or other parts of the engine. The clip has a hole through which a bolt seems to go. I can't seem to find a bolt hole along the body where the clip would mount. ANy ideas or pictures would help. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 10, 2015 Share Posted February 10, 2015 one spot off the idler arm upper bolt should have a bracket to support it Quote Link to comment Share on other sites More sharing options...
overdrive Posted February 11, 2015 Share Posted February 11, 2015 On my '70, it is mounted on the front, lower bolt for the motor mount bracket. Dan Quote Link to comment Share on other sites More sharing options...
jja Posted February 11, 2015 Author Share Posted February 11, 2015 Thanks guys. So the eye clip (?) affixes to the end of a bolt that protrudes out. I saw in a manual that there may be two of these eye clips. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 11, 2015 Share Posted February 11, 2015 one off the idler are bolt and one off the motor mount Quote Link to comment Share on other sites More sharing options...
