Murphy Posted April 21, 2015 Share Posted April 21, 2015 I have access to the 3 small gauges (volts,fuel, & temp) without the mounting brackets, are the current indicator lights mounted on the same brackets? Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 21, 2015 Share Posted April 21, 2015 Murphy I have looked at the AMP gauge and gen light mounting and they are different. I myself have access to a stock AMP gauge and have a left over gen light bracket. I already removed the big fuel gauge for a stock 5500 redline tach, Quote Link to comment Share on other sites More sharing options...
Andreas Posted April 21, 2015 Share Posted April 21, 2015 In addition, the printed circuit is different for both options Quote Link to comment Share on other sites More sharing options...
Murphy Posted April 21, 2015 Author Share Posted April 21, 2015 I realize the PCB is different, just needed to know if I need to search for the gauge mounting brackets.................... Quote Link to comment Share on other sites More sharing options...
Murphy Posted April 23, 2015 Author Share Posted April 23, 2015 Another question guys............can the face of a speedometer be switch out? (column shift vs floor shift) style?? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted April 23, 2015 Share Posted April 23, 2015 another thing to this swap, some of the wires in the plug for the cluster have to be relocated Quote Link to comment Share on other sites More sharing options...
Leghome Posted April 23, 2015 Share Posted April 23, 2015 In another thread I just looked but can not remember which one there was a floor shift tach for around $150. It might have been the thread about the tach not working. Quote Link to comment Share on other sites More sharing options...
Bluemalibu Posted April 23, 2015 Share Posted April 23, 2015 Another question guys............can the face of a speedometer be switch out? (column shift vs floor shift) style??      Murphy, you usually need to immobilize the drum behind the face, to be able to work the push-on needle off of the speedometer to swap them out. Just two screws on the face removes it. Be sure to re-use the rubber insulators on the two rear screws in the middle of the back of the speedo to limit needle vibration.      A quick band-aid fix until you find a donor floor-shift speedo, is to reface your own with the heavy vinyl adhesive face, covering the shift indicator. It can be removed later with a hair dryer if necessary.    http://www.whitegauges.net/products/1970%252d1972-Chevrolet-Chevelle-Malibu-White-Face-Gauges.html                               Doug Quote Link to comment Share on other sites More sharing options...
Murphy Posted April 23, 2015 Author Share Posted April 23, 2015 Thanks Doug, I found a few floor shift speedo's  (used) but didn't know if the face was removable. When I installed the Shiftworks Tach for the clock last year, I covered the gear selector on my speedo with black tape. I am now prepping for the idiot light to gauge swap & figured the speedo fix should be correctly fixed at the same time. Quote Link to comment Share on other sites More sharing options...
Bluemalibu Posted April 24, 2015 Share Posted April 24, 2015  Ah, yes... the ol' "Since this is going to be off anyway, why don't I... " snowball cascade!     I too swapped in the Shiftworks tach several weeks ago for the clock, but my snowball is still gaining momentum heading downhill, so, I haven't gotten a chance to see it in action yet. Do you have yours working through a stock ignition, HEI, or MSD box?  I was told that they've corrected the problems that they were having with the MSD's... I hope that that is the case. Quote Link to comment Share on other sites More sharing options...
Murphy Posted April 24, 2015 Author Share Posted April 24, 2015 Bought after market HEI setup, so far so good for $50 distributor. Quote Link to comment Share on other sites More sharing options...
Bluemalibu Posted April 24, 2015 Share Posted April 24, 2015 Â Thanks... Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 27, 2015 Share Posted April 27, 2015 Murphy here is my finish swap again I didn't buy from Sonnie just brought the needed gauges as I had a tach on hand. I sent just under $300 for the AMP gauge and the water and fuel gauge. The PCB for a gauge cluster is under $70. Quote Link to comment Share on other sites More sharing options...
Murphy Posted April 27, 2015 Author Share Posted April 27, 2015 Looks good Robert, I'm working towards something similar, I'm getting the Tachman to convert the AMP gauge to volts......... Quote Link to comment Share on other sites More sharing options...
