Onetech Posted August 19, 2015 Share Posted August 19, 2015 Had a nasty vibration come and go the last couple weeks and finally the water pump bearing gave out and leaked fluid on the floor today. Got the old water pump and fan assembly out but can't get the fan to separate from the hub. I removed the 4 bolts holding the fan to the belt housing? unit and it seems that the fan is press fitted to the main water pump shaft? Or did someone use a heavy duty bonding agent to hold the water pump to the belt housing. I don't want to damage the fan unit, so a little advice would help. Thanks in advance. I have a 1970 Monte with the standard 350 v8. I can see that the water pump and the fan have 1\4" plates that sandwich the belt housing and the holes are aligned. If we need pictures, I can take some time tomorrow and post them. Ron It's been a while since I last posted, but life got the better of me when my company shut down on us unexpectedly on April 27th and I was unemployed for 8 weeks while looking for a new job. First time in 29 straight years I ever had to face unemployment and the prospect of having to sell my car. But all worked out, and I am once again teaching, this time it's industrial maintenance technicians instead of PC repair technicians. Quote Link to comment Share on other sites More sharing options...
monte70car Posted August 19, 2015 Share Posted August 19, 2015 Ron it sounds like rust has build up on the shaft. I would soak the shaft and fan with WD-40 or any spary lube you might have let it sit and then pray the fan mount from the pulley. Quote Link to comment Share on other sites More sharing options...
Leghome Posted August 19, 2015 Share Posted August 19, 2015 One thing I have done in the past on this type of problem is to take a torch propane or acetylene and put some heat on the shaft and they usually will come apart. Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted August 19, 2015 Share Posted August 19, 2015 I did mine a couple months ago and didn't have any trouble, it must just be rusted on. Try some wd40 or pb blaster a little heat may help be careful it don't flair up and burn you. Use a new water pump not a remain an put some never seize on it when going back together. Quote Link to comment Share on other sites More sharing options...
GatorDog72 Posted August 19, 2015 Share Posted August 19, 2015 When working on old cars, I was always told: "When in doubt, use excessive force!" Some PB Blaster and a big hammer should do the trick! Quote Link to comment Share on other sites More sharing options...
Onetech Posted August 25, 2015 Author Share Posted August 25, 2015 PB blaster, wide blade putty knife, pair of screw drivers, and a hammer finally coaxed the fan off the pully shaft. No rust in there, just an extremely tight fit. The new water pump slid right into the fan with very nice fit. So far, no leaks, an nice smooth flow of coolant through the radiator, and no more terrible sounds from the bad bearing. Quote Link to comment Share on other sites More sharing options...
