rsorg Posted April 17, 2016 Share Posted April 17, 2016 I am having a difficult time finding the solenoid switch by the carb, Does the 72 have a soleniod switch by the carb for the kockdown to work ?can some body send me a picture of this ,thanks, Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted April 17, 2016 Share Posted April 17, 2016 The solenoid switch at the Carb I believe was for the A/C unit. As the A/C kicked in, the motor would bog some, so that switch helped maintain idle. Don't have a pic of it handy but it is located at the front driver side of Carb. If it is there, you will know it! Yes, the 72 had it........................ If I find a pic, will let you know. Doug Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted April 17, 2016 Share Posted April 17, 2016 As I reread your Post, not sure we were talking about same thing! The Kick Down switch for the TH400 is located just up under dash just right of Throttle pedal assy and works in conjunction with throttle. There is a little stem that when acceleration is pushed, that throttle linkage moves against stem pushing it forward. When throttle is released, linkage disengages from switch and a spring moves the switch back This also used to aid operation of functioning Cowl Hood. So, both switches do different things and are not interchangeable. Doug Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted April 17, 2016 Share Posted April 17, 2016 Okay, finally found a pic of the device hooked up. So here it is. Again, this is 1st pic for the A/C. The last for the TH400 Kick Down Switch. Because I wasn't sure what you were after, I just included a bunch of info in case it is useful to you. Good luck on what your after. Doug Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 18, 2016 Share Posted April 18, 2016 Doug the kick down switch worked both the kick down of the trans and open a inner door in the cowl induction hood. Both the switch and bracket can be brought through the aftermarket along with the harness. Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted April 18, 2016 Share Posted April 18, 2016 Yeah, I knew it is dual purpose and didn't think about including that little nugget. Don't know if it's age or just me being me...................... Doug Quote Link to comment Share on other sites More sharing options...
rsorg Posted April 18, 2016 Author Share Posted April 18, 2016 Guys, I am not quite sure ,but my passing gear will not engage when I mash the pedal to the floor on my turbo 400 ,I am going to replace the switch that is by the gas pedal,not quite sure how to adjust the new switch, I am told that the passing gear is engaged electrically,I do remember along time ago that I put a piece of black rubber hose around the stub of the switch to aid in the kick down switch to work ,but now it does not engage at all, I went on various sites to buy new kick down switch and rockauto, aureoles, auto zone ,shows a solenoid with 1 wire and 2 holes for mounting ,not sure what that is or thought that would be somethingI would need to mount on the carb, thanks for your help.Roger Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 19, 2016 Share Posted April 19, 2016 Roger this is the kickdown switch http://www.ss396.com/chevelle/ATE-2101.html most of the after market vendors carry it. If the arm is all the way down you can pull it up and it will center it self. You might be able to find it at a GM dealer as well. Quote Link to comment Share on other sites More sharing options...
rsorg Posted April 19, 2016 Author Share Posted April 19, 2016 I ordered one of these switches that goes by the gas pedal,from the parts place ,hope this will take care of my ,passing gear problem, while driving the monte at about 40mph, I reached down and pulled on the switch and the car went into nuetral, I thought the passing gear would kick in but did not, and I will start with replacing the kick down switch. thanks a lot, Roger Quote Link to comment Share on other sites More sharing options...
