71MonteCarloMD Posted June 19, 2016 Share Posted June 19, 2016 When my son and I removed left side (driver) fender, we found this wire as we couldnt find any possible connection, does anyone know from pictures? Quote Link to comment Share on other sites More sharing options...
orbit Posted June 19, 2016 Share Posted June 19, 2016 Looks like the proportion valve wire Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted June 19, 2016 Author Share Posted June 19, 2016 Where would I find the proportion valve? Quote Link to comment Share on other sites More sharing options...
monte70car Posted June 20, 2016 Share Posted June 20, 2016 The proportion valve is on the inside of the frame towards the motor and trans. The wire will turn the brake light on at the dash if there was an issue. Quote Link to comment Share on other sites More sharing options...
bigtankjones Posted June 20, 2016 Share Posted June 20, 2016 That's what I was gonna say to was the brake proportioning valve. Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted June 20, 2016 Author Share Posted June 20, 2016 Ert and Tony, thanks and do you have a picture where it is as I am not sure if previous owner removed it? Rick Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted June 20, 2016 Share Posted June 20, 2016 The factory proportioning valve location is on the inside of the frame on drivers side (location near/across from oil filter). See pic. Doug . Quote Link to comment Share on other sites More sharing options...
monte70car Posted June 20, 2016 Share Posted June 20, 2016 Best way to find it trace the brake line front the master cylinder down as it ties to the top. Or you can trace the line from the driver side wheel to the valve as it ties to the front. Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted June 20, 2016 Author Share Posted June 20, 2016 Ert, thanks and will check. Rick Quote Link to comment Share on other sites More sharing options...
