Andreas Posted December 15, 2000 Share Posted December 15, 2000 I received the steel inner fenders from www.musclecarsonly.com yesterday. Only 4 days after order! Upon first inspection, they look very good. All dimensions seem to be equal to the plastic fenders and the pre-drilled mounting holes seem to be in the same spots. They are EDP Powdercoated and therefore corrosion protected. They are much heavier than the plastic fenders, which is probably not a bad thing... Not too bad for $99 a piece... I will take some pics of both plastic and steel and put them on my website soon. It will be a while until I install them, because I will paint the side of the inner fenders facing the engine compartment the same color as the body and the side facing the wheels with POR-15 . Yeah, try to do this with plastic fenders!! ------------------ 71 Monte 383 "The Full Monty" 86 Monte LS ZZ4 "The Gray Mouse" http://go.to/Monte Member NMCOA, FGMCC "It ain't a car if it's not a Monte" Link to comment Share on other sites More sharing options...
Grease Posted December 15, 2000 Share Posted December 15, 2000 Glad to hear they look good . and the price is great . i was just today pricng those from a different vendor at 129.00 each . what a deal . mike Link to comment Share on other sites More sharing options...
MC-71 Posted December 16, 2000 Share Posted December 16, 2000 TEST Link to comment Share on other sites More sharing options...
MC-71 Posted December 16, 2000 Share Posted December 16, 2000 Sorry for the test. Been having trouble posting lately. The steel liners you bought are made by Goodmark they are nice and should fit OK. You might have to drill a couple of holes because I think Chevelle fender holes are layed out different. I have new GM liners that I had painted base coat clear coat in black. www.goodmarkindustries.com They supply almost all the repro body parts in everybodys catalog. Get their catalog. It has a lot of stuff. Link to comment Share on other sites More sharing options...
Monte Posted December 16, 2000 Share Posted December 16, 2000 Andreas, just so that I am clear are they the same as the plastic ones as far as how they mount? Do you think you are going to have to modify them to get them to work at all? Did you have a plastic liner out of the car to compare them too? Monte Link to comment Share on other sites More sharing options...
Monte Posted December 16, 2000 Share Posted December 16, 2000 Did you order them for a Chevelle or a Monte Carlo? Link to comment Share on other sites More sharing options...
Andreas Posted December 16, 2000 Author Share Posted December 16, 2000 They are Chevelle fenders, but I am sure that I can make them work. As far as I can see, I will have to drill two holes, one for the side/parking light grommet and a second one for the additional fender bolt... You can see old vs. new fenders on my website now at http://go.to/Monte I also finally finished changing the body bushings from rubber to polygraphite today, ufff! ------------------ 71 Monte 383 "The Full Monty" 86 Monte LS ZZ4 "The Gray Mouse" http://go.to/Monte Member NMCOA, FGMCC "It ain't a car if it's not a Monte" Link to comment Share on other sites More sharing options...
Guest Posted December 16, 2000 Share Posted December 16, 2000 Those look excellent andreas! Ya need some stickers for em.....lol ------------------ 72 Monte Carlo My Monte Carlos webpage http://darkforcemaster.tripod.com/pics/index5.html Link to comment Share on other sites More sharing options...
MeanMonte Posted December 17, 2000 Share Posted December 17, 2000 hey just for the purpose of knowing can u weigh the plastic ones vs steel ones btw they look good im suprised they match so close, thanks for the info Link to comment Share on other sites More sharing options...
Andreas Posted December 17, 2000 Author Share Posted December 17, 2000 I can't weigh them that easily. I would think the the plastic is about 6 lbs. each and the steel are about double the weight... ------------------ 71 Monte 383 "The Full Monty" 86 Monte LS ZZ4 "The Gray Mouse" http://go.to/Monte Member NMCOA, FGMCC "It ain't a car if it's not a Monte" Link to comment Share on other sites More sharing options...
MeanMonte Posted December 20, 2000 Share Posted December 20, 2000 hey thats cool i understand thanks anyhow!!! Link to comment Share on other sites More sharing options...
Guest Posted December 20, 2000 Share Posted December 20, 2000 The metal and plastic inner fenders mount the same as they are really the same parts. Montes have a different p/n than Chevelles for the plastic ones due to the different holes drilled for the battery tray to me mounted. But if you look at alot of the Chevelles that have been redone and uses plastic inner fenders, you will notice thay are Monte units. Link to comment Share on other sites More sharing options...
Guest Posted January 8, 2001 Share Posted January 8, 2001 i got the plastic inner fenders and i cant get them to line up at all. i had the car to the frame rails. it fit to the fender like a glove off the car when it went on it was a different story. they buckeled in towards the motor. i will be tring again come spring any suggestions???!!! ------------------ please restore em' and not crush em' Link to comment Share on other sites More sharing options...
