footballubet Posted April 13, 2008 Share Posted April 13, 2008 What are the advantages and disadvantages of going with a 9" brake booster. I'm thinking about using the 9" just to clean up the engine bay a little bit. Don't need it for room, as I'm running a SB. Just wondering about less reserve vacuum that's all. Give me your thoughts. Thanks Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 13, 2008 Share Posted April 13, 2008 i would say room around the valve cover scott. but i could be wrong Quote Link to comment Share on other sites More sharing options...
kc8oye Posted April 13, 2008 Share Posted April 13, 2008 less power assist too.. unless you run a dual-diapragm.. there is another post in modifiers I believe discussing this. search for brake boosters Quote Link to comment Share on other sites More sharing options...
bobsmc Posted April 14, 2008 Share Posted April 14, 2008 http://cgi.ebay.com/ebaymotors/67-72-Che...1QQcmdZViewItem this is the set up i put on mine. make him a low ball offer. i think i paid 229. nice stuff works good and looks great. Quote Link to comment Share on other sites More sharing options...
footballubet Posted April 14, 2008 Author Share Posted April 14, 2008 Looks like a nice set up, and I don't need the lines and proportioning valve. Might just try that. Quote Link to comment Share on other sites More sharing options...
Reaper Posted April 15, 2008 Share Posted April 15, 2008 I bought a chroms dual booster that is 7" I think with the master cylinder for about that off ebay... might be 8" but it works and looks good. The master cylinder has two screws in the top of it instead of the bar that slides over the top. If I think about it I will take a pic.... Tom Quote Link to comment Share on other sites More sharing options...
bobsmc Posted April 15, 2008 Share Posted April 15, 2008 the guy i bought my stuff off was local . i bought it off ebay but went and picked it up. Quote Link to comment Share on other sites More sharing options...
footballubet Posted April 15, 2008 Author Share Posted April 15, 2008 He won't take less than $290...Big savings off the "Buy it Now" price of $299 Quote Link to comment Share on other sites More sharing options...
DavidTX Posted April 15, 2008 Share Posted April 15, 2008 If you have a stock cam you can get by with the smaller booster. With a larger cam, you will have less vacuum and can have problems. Quote Link to comment Share on other sites More sharing options...
Reaper Posted April 16, 2008 Share Posted April 16, 2008 I use a canister and my brakes still arent the best but they work Dont really think its from lack of vacuum though... just bad luck with brakes. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted April 16, 2008 Share Posted April 16, 2008 one thing about low vacuum is trying to set your idle speed too low!!! I have a pretty mild cam.. but when I had the idle speed down to 500rpm in gear, the pedal was noticbly harder (13" of vac) then when I had the idle @ 750 (16" vac) big cams need to idle fast.. that's where high stall converters are nice too Quote Link to comment Share on other sites More sharing options...
Heckeng Posted April 30, 2008 Share Posted April 30, 2008 I just swapped out my stock booster for a dual diaphragm 8" unit. I am disappointed to say that the performance was better with the stock unit. I am running around 10 inches of vacuum at idle, which is not quite enough for the dual 8" booster. The positive side is that I have cleaned up the engine compartment nicely. I will be getting an electric vacuum pump to clutter things back up now Quote Link to comment Share on other sites More sharing options...
