Thermostat
 Always like a 160 degree thermostat. Unless you purchase a Mr gasket high flow thermostat drill a 1/8 hole on the flat part to "purge" the air out of the system quicker.
Thanks !!!!!!
  • You're Welcome 1
Second on the 160 degree thermostat. I just burp the system and don't drill the hole however. Either way is perfectly acceptable though. Other cars I have a hole drilled in the flange and it works well.
