Chris shipley Posted July 18, 2023 Share Posted July 18, 2023 Anyone's preference what thermostat they like and what degrees Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted July 18, 2023 Share Posted July 18, 2023 Always like a 160 degree thermostat. Unless you purchase a Mr gasket high flow thermostat drill a 1/8 hole on the flat part to "purge" the air out of the system quicker. 2 Quote Link to comment Share on other sites More sharing options...
Chris shipley Posted July 18, 2023 Author Share Posted July 18, 2023 8 hours ago, MC1of80 said: Always like a 160 degree thermostat. Unless you purchase a Mr gasket high flow thermostat drill a 1/8 hole on the flat part to "purge" the air out of the system quicker. Thanks !!!!!! 1 Quote Link to comment Share on other sites More sharing options...
cbolt Posted July 18, 2023 Share Posted July 18, 2023 Second on the 160 degree thermostat. I just burp the system and don't drill the hole however. Either way is perfectly acceptable though. Other cars I have a hole drilled in the flange and it works well. 2 Quote Link to comment Share on other sites More sharing options...
Chris shipley Posted July 18, 2023 Author Share Posted July 18, 2023 1 hour ago, cbolt said: Second on the 160 degree thermostat. I just burp the system and don't drill the hole however. Either way is perfectly acceptable though. Other cars I have a hole drilled in the flange and it works well. 👍 Quote Link to comment Share on other sites More sharing options...
Whons Posted July 19, 2023 Share Posted July 19, 2023 I have been using a 160 ^ thermostat too. 1 Quote Link to comment Share on other sites More sharing options...
