Wilddan72 Posted December 17, 2023 Share Posted December 17, 2023 Hi all, after installing my warning light dash everything works good, all lights and accessories as they should. Except , when I put signals on, left or right both dash arrows flash. When I activate hazards, the lights in the speedometer pod flash, not the arrows, checked grounds and connections. I did replace lights in cluster with leds but not signals or warning lights, any ideas ? Thanks Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted December 18, 2023 Share Posted December 18, 2023 My first thought was to check grounding but you already checked. Check this thread out that may help? Gauge problems: Quote Link to comment Share on other sites More sharing options...
DragCat Posted December 18, 2023 Share Posted December 18, 2023 Just throwing this out from my blue oval experience if I understand correctly. You changed the instrument bulbs to LED's? Someone can verify if you also need to replace the flasher can. 1 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted December 18, 2023 Share Posted December 18, 2023 Hi Dan, If I read you correctly, you've replaced the original basic dash with a newer basic one ? Is it an aftermarket piece or one you got from another car (of a different year) ? Did you also replace the printed circuit board ? To me, it sounds like you've crossed up or shorted something on the circuit board. Maybe it's just pressed against something that's re routing where the electricity to the wrong light. Could also be that you've gotten one from a different year........ My understanding is that there are slight differences between them and that might be the issue. Just a couple thoughts.... I'm sure someone has more experience at this, but it may be somewhere to start. Welcome to the club, you'll find it's a great place to solve many "Monte" mysteries.... Scott. Quote Link to comment Share on other sites More sharing options...
