BCourv99 Posted February 23, 2009 Share Posted February 23, 2009 Hi, I am looking for some info on what it would take to change my 70 MC powerglide tranny to a th350. Specifically does anything need to be changed in the column itself? I have the indicator for a 3 speed but am not sure what else i need. Thanks. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted February 23, 2009 Share Posted February 23, 2009 i guess just to cover all the bases... are you SURE it's a 'glide and not a TH350? Quote Link to comment Share on other sites More sharing options...
BCourv99 Posted February 23, 2009 Author Share Posted February 23, 2009 yes. Is there some sort of detent or something in the column that holds it in selected gear? Quote Link to comment Share on other sites More sharing options...
kc8oye Posted February 23, 2009 Share Posted February 23, 2009 basicly, the th350 should just bolt right in and everything will hook up as it was... you will need to move the crossmember problaby, but that should just unbolt and slide back or forward, the holes are already in the frame. Quote Link to comment Share on other sites More sharing options...
RichG Posted February 23, 2009 Share Posted February 23, 2009 If I recall correctly, the dash indicator is just a plastic pointer with a string attached to it. The string has a ring terminal that screws to the "shifter bowl" on the column. As the column moves with the shifter, the pointer moves. So to answer the question, nothing need to be done except align it. Put shifter in neutral, align pointer to neutral and you should be goo to go. Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted February 23, 2009 Share Posted February 23, 2009 Rich is right with his description, I just had mine apart, just a small phillips head into the shifter bowl. Quote Link to comment Share on other sites More sharing options...
