Posi rear - gear ratio?
I had to take the differential cover off to replace a broken bolt. While I still have the cover off, I'd like to learn as much as possible about the guts of this thing. I was told this was a posi and I think it is but is there an easy way to tell by looking inside? Also can you determine the ratio by counting the gears or something? I am pretty sure you can turn the drive shaft and count the rotation of the tires or something but thought there might be an easier/more accurate way while the cover is off. I'm sure it will be some time before I do this again...
by the way, it has 12-bolts in the pan cover.
Thanks in advance!
Dave
'70 Monte Carlo
smokecracker@hotmail.com
http://www.zoominternet.net/~cotton3
This had been answered here:
http://www.firstgenmc.com/ubb/Forum4/HTML/000055.html
You can count the number of teeth on the gears, but I think that you will not be able to count them on the pinion gear without removing the carrier. Hence, the rotating method is easier...
If you see springs and/or clutch packs or other weird stuff inside the carrier, its a posi. If you only see four conical shaped spider gears, it is an open differential (no posi).
71 Monte 383 "The Full Monte"
86 Monte LS ZZ4 "The Gray Mouse" FOR SALE!
Andreas' Monte Carlo Site
Member NMCOA, FGMCC (Event Coordinator)
[This message has been edited by Andreas (edited 03-05-2002).]
You can count the pinion teeth while the gears are still in the rearend, but it is a pain. Most all GM ring & pinions have the teeth count stamped in the ring gear, like 41:15 for 2.73, 46:14 for 3.31, 41:10 for 4.10's etc. Also stamped in the same location is the part number & a date code. just rotate the gear and wipe the oil off the edge & you should find it.
The axle housings are code stamped for each ratio. Of course, unable to find decoding housing location book. When found will post.
Ed
'71 Black 350/700R4 Mar. 31th completion date
'71 Saddle SS454 orginial
'71 Project, 2" chop planned
hey dave look under the general section on the topic of how to id rear end ratios it is made by me covering all years "this is only true if your ratio was not changed since it came out of the factory....
hope this helps alex
alex
hmmmm the sound of wrenches turning and... slowly out from the garage emerges a luxury muscle car that is anything but... it is.. the monte carlo with a new edelbrock performer rpm power package and new 350 block stroked to 377 cid.
thanks for all the feedback...
I know there are only 2 gears - one small one that woudl be attached to the drive shaft if it continued through the housing and a larger one that the axle would run through the center of. Their is something that looks like an overgrown marshmellow oposite the larger gear (attached to the right rear axle). No other gears visible.
I think I'll look for the numbers this weekend and post them here...
Thanks again all!
Dave
Dave
'70 Monte Carlo
The "marshmellow" is what rear-end freaks call "carrier" biggrin.gif. This would be the part which would contain all elements of the positraction unit in it... The carrier should have at least one opening, turn the wheels if you can not see it. Then, if you can not make out four smaller gears inside of the carrier, but all kinds of other stuff such as plates and springs, chances are that you have a positraction unit.
[This message has been edited by Andreas (edited 03-06-2002).]
OK, i finally got under the car today and was not able to find any stamped markings on the gears. I did find, in white ink of some sort, a line with a cirle around it and the number 45 immediately following it. This sequence is written on both the small and large gears. I decided to count the teeth on the gears but seems strange... I found 43 teeth on the big one and 13 on the small one.
Does this sound like 3.30 posi? Any idea what the (l)45 marking is?
