Correct Speedo Reading
I know this issue has been discussed in previous conversations and I have attempted to understand and use the calculators in order to determine what my correct speedometer reading would require based on the following:
In the process of changing out entire drivetrain
From 350 CI to 402 CI
From TH350 to TH400 Trans.
From .273 10 Bolt to .331 12 Bolt Posi Rear Axle
Rear tire size remains the same @ 235/R70 w/ 15" Rim
Based on my understanding the following applies using the calculator(s) provided:
Tire dia. @ 27.95"
331 Rear Axle ratio
18 Tooth Drive Gear
The formula says I need to change my driven gear from currently 37 teeth to 43 teeth for correct speedo reading.
I believe the driven gear housing will also need to be replaced to a 40 to 45 tooth gear housing.
Does this seem correct assuming my calculations are accurate?
Looking for a confirmation that I had used the math correctly and not left out anything else that would cause me grief. Not totally confident and don't want to throw money around on something I may have overlooked.
All comments and suggestions aprreciated
All have a GREAT day.....
Doug
Hey thanks for the confirmation Scott.
My first attempt at using this formula and needed some support.
Seems like the more I learn, the less I know compared to the experiences you all have had.
Almost 30 years at the same job and when any of the newer guys raze me about my knowledge, I simply reply (I have advanced so far beyond that point, I have already forgotten what you are just beginning to learn).
I know how they feel when I solicit questions in this forum.
Much appreciated!
Doug
Doug
I need to remember that line! lol
