Guest mvautrain Posted December 31, 2009 Share Posted December 31, 2009 I was wondering if you can get a new build sheet made also window sticker? Thanks Mike Link to comment Share on other sites More sharing options...
Dans '70 Z20 Posted December 31, 2009 Share Posted December 31, 2009 I think you are able to get a build sheet if your car was built in Canada. I think you can order a restoration packet from Canada too. Built in USA you are sh*& outta luck. Dan Link to comment Share on other sites More sharing options...
CrazyDavey Posted December 31, 2009 Share Posted December 31, 2009 don't know about the build sheet but I see repo window stickers all the time. I don't know where they get them but I know they're out there. You can tell they're repo though, just don't have quite the same format and font style on the ones I see..... Link to comment Share on other sites More sharing options...
monte70car Posted January 1, 2010 Share Posted January 1, 2010 There is a company on the web that makes repo build sheets. What they do is use preprinted forms and copy your information on to the sheet. They can also age the sheet so it looks to be an org. As for the window sticker you can buy them as well. Link to comment Share on other sites More sharing options...
Guest mvautrain Posted January 1, 2010 Share Posted January 1, 2010 Not that I really need either one of these but I would like to have them. My car actually had a original build sheet under the back seat I tried to remove it for a couple of hours and the way it was in there the only thing I did is keep tearing it. The gas tank has been out door panels off 1 under back seat suppose there could be one under head liner original never been out???????????????????????? Link to comment Share on other sites More sharing options...
overdrive Posted January 1, 2010 Share Posted January 1, 2010 Is the sheet in the lower section of the back seat? What is holding it so well that you can't remove it? Link to comment Share on other sites More sharing options...
Guest mvautrain Posted January 1, 2010 Share Posted January 1, 2010 It was between the actual seat frame and the springs I believe. That was about 8 years ago now it never came out except in little pieces. I still would like to have one seeing how the car is a original big block car with a decent amount of options. Link to comment Share on other sites More sharing options...
