monte70car Posted September 3, 2010 Share Posted September 3, 2010 Went to swap out the fuel pump on monte420's small block tonight and ran into a problem. She brought this pump Holley 12-327-11 Mechanical Fuel Pump which says it will fits but it hits the cross member on the side and where the motor mount bolts. We are replacing it the org. one as it leaks gas out of the pump of the pump. Anyone else use that pump number if so what all did you have to do to get it fit. Quote Link to comment Share on other sites More sharing options...
Ian Posted September 3, 2010 Share Posted September 3, 2010 ERT look here... http://www.firstgenmc.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=266424&page=1 Quote Link to comment Share on other sites More sharing options...
monte70car Posted September 3, 2010 Author Share Posted September 3, 2010 Ian I see where some got it to fit and some didn't. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted September 3, 2010 Share Posted September 3, 2010 i used an O.E-spec pump from the parts store.. it has no problem support my 300hp 350. (And it fits) Quote Link to comment Share on other sites More sharing options...
Winston Wolf Posted September 3, 2010 Share Posted September 3, 2010 Go to post #265427 - 06/03/10 Fuel Pump Quote Link to comment Share on other sites More sharing options...
Ian Posted September 3, 2010 Share Posted September 3, 2010 Go to post #265427 - 06/03/10 Fuel Pump Here is his picture.. Quote Link to comment Share on other sites More sharing options...
monte70car Posted September 3, 2010 Author Share Posted September 3, 2010 The owner was supposed to call a local parts house we know a guy at and see if he has a stock pump, I also gave her the option of running an elec. pump which will be easy to hook up since power is already in place. I was able to turn the bottom half of the Holley pump so it would work but then it hit, I try and grab some pictures later today. Quote Link to comment Share on other sites More sharing options...
AL M Posted September 3, 2010 Share Posted September 3, 2010 All I had to do is rotate the bottom and it fit just fine...Has your front end ever been hit? Just a thought. Quote Link to comment Share on other sites More sharing options...
monte70car Posted September 3, 2010 Author Share Posted September 3, 2010 Al as far as I know the front end has never been hit. Quote Link to comment Share on other sites More sharing options...
monte70car Posted September 4, 2010 Author Share Posted September 4, 2010 Fresh eyes and and better light its on with paper clearance between the frame and fuel pump just can't use the stock metal line . Quote Link to comment Share on other sites More sharing options...
Ian Posted September 4, 2010 Share Posted September 4, 2010 Ert what shape are the engine mounts in? New ones would make it sit a little higher, I think... Quote Link to comment Share on other sites More sharing options...
monte70car Posted September 4, 2010 Author Share Posted September 4, 2010 Ian the motor mounts look good I do have a picture of it on my cam just haven't downloaded it. Quote Link to comment Share on other sites More sharing options...
monte70car Posted September 4, 2010 Author Share Posted September 4, 2010 Here it is the picture of the new pump got room from the bottom of the pump to the cross member its just the top to the side of the pump. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted September 4, 2010 Share Posted September 4, 2010 that will hit when the engine torques over in the cradle. my air cleaner moves over almost 3 inches when I nail it from a stand still and it moves towards the passenger side... Quote Link to comment Share on other sites More sharing options...
AL M Posted September 5, 2010 Share Posted September 5, 2010 Sure looks perdy...get those new mounts in!!! Quote Link to comment Share on other sites More sharing options...
monte70car Posted September 7, 2010 Author Share Posted September 7, 2010 Had it running briefly and able to goose it and the motor does not rock at all, even my big block don't rock so I think it will be good. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted September 7, 2010 Share Posted September 7, 2010 it won't rock much in park ert.. the problem is when it's in gear and there is 'reverse torque' from the drive train the driveshaft tries to turn one way, and the engine is going to try and turn the other way in the cradle. trust me, it WILL hit. it's also possible it's already hitting, and the engine isn't rocking because the fuel pump is crammed up against the frame and stopping it. I would seriously advise against running it like that. Quote Link to comment Share on other sites More sharing options...
