Chevyss Posted February 11, 2011 Share Posted February 11, 2011 The Monte is missing again (engine miss)!! It's happened before and we've pulled the plugs and cleaned them. It was good for a while, but since it was in for some body touch up it's started dropping a cylinder. We put a step hotter plug in it to help it so it won't load up. What plug does everyone put in their BBCs? I never have had much luck with AC Delco plugs. What about Autolite?? ND or NGK?? Thanks in advance Quote Link to comment Share on other sites More sharing options...
wallaby Posted February 11, 2011 Share Posted February 11, 2011 I have always had good luck with the Autolite powertip plugs. They are pretty basic, but seem to work well at a reasonable cost. Everybody has 'em too. My engine just doesn't burn clean enough to make platinum plugs a worthwhile advantage....I end up changing them out well before they wear out anyway. Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted February 11, 2011 Share Posted February 11, 2011 Been a firm believer in NGK R8 for street use, R9 when spraying the big blocks. Quote Link to comment Share on other sites More sharing options...
monte70car Posted February 12, 2011 Share Posted February 12, 2011 Got a set of NKG's in my big block then I have another set of A/C Delco's for a backup. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted February 12, 2011 Share Posted February 12, 2011 I run Autolite plugs never had an issue. Like Mark I just run standard plugs I change them too often. Quote Link to comment Share on other sites More sharing options...
Heckeng Posted February 12, 2011 Share Posted February 12, 2011 NGK R5671A-7, these are the "V" power ones. I doubt I get much extra power from them however! Quote Link to comment Share on other sites More sharing options...
680HPStroker Posted February 24, 2011 Share Posted February 24, 2011 I'll second the NGK R8 plugs. I have straight cut threads in my heads and the NGK's are the only ones that fit my form and function. I can't comment on longevity as I replace my plugs every year no matter how many miles I put on my engine(Off the record a guy at MSD stated NGK's work best with their ignition). Quote Link to comment Share on other sites More sharing options...
Chevyss Posted February 25, 2011 Author Share Posted February 25, 2011 I ended up putting Autolite AP63 plugs in the 502. Seems ok for now. Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted February 25, 2011 Share Posted February 25, 2011 I have used Autolite no real issues,But I love my AC Delco Platinum. Quote Link to comment Share on other sites More sharing options...
