Riznitch Posted March 19, 2011 Share Posted March 19, 2011 Ive searched the site looking for the answer but can't find it so, sorry for reposting. Anyhow, if i have a stock 350 what type oil pump should i get. higher volume or higher pressure? I remember someone saying that for one of these it would be recomended to get a deeper pan (i dont want a deeper pan). Thanks in advance Quote Link to comment Share on other sites More sharing options...
72MC Posted March 19, 2011 Share Posted March 19, 2011 For a stock 350, you only need a stock volume/stock pressure oil pump. If you are set on a higher volume pump, that would be fine. Most high volume pumps come with a second spring(usually pink) for a high pressure application. However, don't use a high pressure pump or the high pressure spring on a high volume pump. Not a good idea even for a mild - highly modified SBC. The higher volume pump will raise pressures slighty just by nature, so to speak (ie. pump trying to push higher volume through the original passages). - Dave Quote Link to comment Share on other sites More sharing options...
Riznitch Posted March 19, 2011 Author Share Posted March 19, 2011 Sweet! thanks dave Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted March 19, 2011 Share Posted March 19, 2011 I agree too, a stock pump will be fine Quote Link to comment Share on other sites More sharing options...
