robs70monte Posted April 2, 2011 Share Posted April 2, 2011 I have a 1986 k5 blazer im tossing together and want some opinions so hears what im working with 1970 350 4bolt main 010 4.000 bore 268h comp cams .454/.454 all new bottom end no run time 193 tbi heads milled to 62cc chambers new bronze guides 3 angle valve job and a full port and polish new 120lbs springs the heads are good to about 4500rpm the high rise marine intake im using a lt1/z28 copy but 1.25 taller and cast iron is good around 4500-7000 speed pro cast pistons flat tops sealed power file fit rings sealed power lifters comp cams push rods 1.5 ratio roller tip rockers 750 holly 1 5/8 headers with thrush glass packs New gm hei distributor all other parts are pretty much stock replacement and im sure im forgetting stuff what do you think im going to get out of this build i dont know whats going to happen with the rpm range difference between heads and intake Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted April 2, 2011 Share Posted April 2, 2011 carbs too big, a 650 is all you'll ever need and will be more responsive Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted April 2, 2011 Share Posted April 2, 2011 Along with the carb being big, you state that the intake is good from 4500 to 7000, Why would you run such a mismatch of intake when your heads are nowhere close to being up to that challenge. I would think you would want to keep port velocity high. Flat top Pistons with 62 cc chambers will get you about 10 to 1 with available fuel you may have some detonation issues. Quote Link to comment Share on other sites More sharing options...
robs70monte Posted April 2, 2011 Author Share Posted April 2, 2011 all these parts I have jest laying around so I'm going to toss some thing together so how do you think a performer intake would work I think I have a 600 holly Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted April 2, 2011 Share Posted April 2, 2011 it would be a much better choice Quote Link to comment Share on other sites More sharing options...
robs70monte Posted April 2, 2011 Author Share Posted April 2, 2011 How well do you think this thing will run for a club together Quote Link to comment Share on other sites More sharing options...
