Murphy Posted May 6, 2011 Share Posted May 6, 2011 How do I determine which automatic is installed, the buildsheet?? Or numbering on the tranny itself?? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted May 6, 2011 Share Posted May 6, 2011 what is currently in it or what it came with? does the trans pan look like the state of Texas (TH400) or a square with a missing a corner? (TH350) Quote Link to comment Share on other sites More sharing options...
Murphy Posted May 6, 2011 Author Share Posted May 6, 2011 It's a TH350, square pan. Looks like I've got a leak where the speedocable attaches....Does that collar just spin off? Next question, where are the markings on the rearend (differential)so I can determine exactly what I have? Quote Link to comment Share on other sites More sharing options...
overdrive Posted May 6, 2011 Share Posted May 6, 2011 My trans was leaking from the same spot. Channel locks will remove the nut with a twist. The speedometer driven gear inside is plastic and mine had wear on the shaft and I had to replace it. The housing it's in has an o-rings on the inside and outside that you'll want to replace. The code for the rear axle is stamped on the front of the passenger axle housing, just outboard of the differential. Sam has a good picture that he may post for you or give you a link. Dan Quote Link to comment Share on other sites More sharing options...
overdrive Posted May 6, 2011 Share Posted May 6, 2011 I found it: axle ID Dan Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted May 6, 2011 Share Posted May 6, 2011 thanks I'm on another computer and couldn't get it Quote Link to comment Share on other sites More sharing options...
Murphy Posted May 6, 2011 Author Share Posted May 6, 2011 Thanks Guys...........Great help! KDG 169 2 What does the KD mean? Quote Link to comment Share on other sites More sharing options...
Murphy Posted May 6, 2011 Author Share Posted May 6, 2011 Also, the build sheet states "GW5 273 Ratio Axle" Thanks again....... Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted May 6, 2011 Share Posted May 6, 2011 When you say its a square pan do you mean square with the one corner off or square? this is a 3 speed auto right. Some did come with powerglide which was a 2 speed auto. Just want to make sure you have the right info. Quote Link to comment Share on other sites More sharing options...
Murphy Posted May 6, 2011 Author Share Posted May 6, 2011 Yea, it's a 3 speed auto... Quote Link to comment Share on other sites More sharing options...
