robs70monte Posted June 16, 2011 Share Posted June 16, 2011 Should i go with a 2500 CFM 16inch fan no shroud (all ready have it) or Dual 10inch fans no shroud 1800 CFM Rating(each fan)3600 total Im using a crappy 2 core radiator so its only about 21inches across im running a 160 thermostat and the fans turn on at 180'F and shuts off at 170'F Quote Link to comment Share on other sites More sharing options...
monte70car Posted June 16, 2011 Share Posted June 16, 2011 Rob I run a flex a lite fan system that has two 12 inch fans on my big block. Quote Link to comment Share on other sites More sharing options...
robs70monte Posted June 16, 2011 Author Share Posted June 16, 2011 I don't think 2 12inch fans would fit on my radiator and the dual 10inch fans im looking at are flex a lite fans the 16inch i have is to Quote Link to comment Share on other sites More sharing options...
robs70monte Posted June 16, 2011 Author Share Posted June 16, 2011 The core its self is only 21inches across Quote Link to comment Share on other sites More sharing options...
monte70car Posted June 16, 2011 Share Posted June 16, 2011 I got this on mine the radiator is a 93 alumin van or truck radiator with plastic tanks. Quote Link to comment Share on other sites More sharing options...
robs70monte Posted June 16, 2011 Author Share Posted June 16, 2011 Ya i think i might look for a cheap radiator and get the dual 12inch or 14inch Quote Link to comment Share on other sites More sharing options...
MonteFox89 Posted June 16, 2011 Share Posted June 16, 2011 I got this on mine the radiator is a 93 alumin van or truck radiator with plastic tanks. SOOO MUCH ROOM! I can camp in that engine bay! I think I want new fans now... Quote Link to comment Share on other sites More sharing options...
Ian Posted June 16, 2011 Share Posted June 16, 2011 Check out the Mark VIII fans. 4500 CFM http://www.firstgenmc.com/ubbthreads/ubb...true#Post210831 Quote Link to comment Share on other sites More sharing options...
MonteFox89 Posted June 16, 2011 Share Posted June 16, 2011 I think we have a set of mark VIII fans here at work actually.... Quote Link to comment Share on other sites More sharing options...
FastClass Posted June 16, 2011 Share Posted June 16, 2011 @ 4500cfm, those are some real air movers. Quote Link to comment Share on other sites More sharing options...
JOHNA01374 Posted June 17, 2011 Share Posted June 17, 2011 A single Mark VIII fan will get the job done and they're about $100 with the necessary relays. Quote Link to comment Share on other sites More sharing options...
wallaby Posted June 18, 2011 Share Posted June 18, 2011 I went throught this last year, and found that the Ford Taurus with the 3.8 V6 uses the same fan as the MKVIII. This is a big help as the "U-pull-it" yards are full of Tauruses and darn few Lincolns...To make it even better, the fan is much easier to remove from a taurus! You darn near have to remove the whole front-end of a Lincoln to get the fan out, where the Taurus can be lifted straight out after undoing just 2 10mm bolts and sniping the wires. I also browsed around and found some great relay blocks with fuses and diodes from a Chrysler nearby...no bolts holding this in, it just snaps in place, but you have to cut a bundle of wires. I got 2 fans, two relay blocks, 6 relays and it cost me less than $40 for everything. Here is a good write-up showing what is needed and how to wire it up: LINKY Quote Link to comment Share on other sites More sharing options...
