70 Iron Posted August 9, 2011 Share Posted August 9, 2011 Just started having a problem with antifreeze coming out the overflow. Its only running around 200 with A/C on & 90 deg out,put another cap from a known good rad ,have a recent new 4 row rad,new pump that came on the crate engine ZZ 454,not over filled,good flow thru rad (looking with the cap removed)Its been doing fine for the last couple of yrs,just started this. No leaks anywhere,I straped a 12oz bottle to the side of the rad and placed the over flow hose in and the bottle filled up after running about 15 miles. Any Ideas what the problem could be ? Thanks, Terry Quote Link to comment Share on other sites More sharing options...
70 Iron Posted August 9, 2011 Author Share Posted August 9, 2011 I believe I found the problem,changed the stat which I think was stuck open and forcing the water to fast thru the rad and pushing it out.Drove for 12 or so miles after the stat open with the bottle still in place and no coolant coming out the overflow. Thanks Terry Quote Link to comment Share on other sites More sharing options...
Canuck Posted August 9, 2011 Share Posted August 9, 2011 Gotta love it when it's a cheap fix. Quote Link to comment Share on other sites More sharing options...
70 Iron Posted August 9, 2011 Author Share Posted August 9, 2011 Yea Aaron,sometimes you get lucky .:-) Terry Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted August 9, 2011 Share Posted August 9, 2011 You got off cheap Terry! Lucky, and a quick and easy fix. Great work Quote Link to comment Share on other sites More sharing options...
black07ss Posted August 9, 2011 Share Posted August 9, 2011 I think Terry found a 5 minute fix for a Monte Great job and happy cruising Quote Link to comment Share on other sites More sharing options...
70 Iron Posted August 9, 2011 Author Share Posted August 9, 2011 Rather be lucky then good anyday Didn't even need to go to the parts place,had the empty water bottle on hand ,2 tie wraps ,anti,and the stat was a spare that I keep on hand Terry Quote Link to comment Share on other sites More sharing options...
