george_1970_406 Posted October 24, 2011 Share Posted October 24, 2011 My 1970 406 with around 2000 miles on it smokes. The car starts and does not smoke until it is up to running temp 180. The car barely goes over 180 even in the Hot [you said a naughty!] Missouri summers. I put my hand in the exhaust pipe and there is black buidup. Also after it has not been started for a while a light condensation appears but goes away. Is it running to Rich? Are the rings toast already? Please help! George Quote Link to comment Share on other sites More sharing options...
ripleydale Posted October 24, 2011 Share Posted October 24, 2011 I wouldn't worry about the condensation, very normal. You say it smokes but you aren't telling us if it's using oil. How much between quarts? Might want to try a compression test to see if you can determine where you might be losing oil, through the rings or valves guides. The black buildup in the tail pipe could indicate it's running rich. Quote Link to comment Share on other sites More sharing options...
DavidTX Posted October 24, 2011 Share Posted October 24, 2011 If it was white smoke it would be oil but black smoke indicates it is running rich. The first thing I would check is the choke. Sounds like it may be partially closed when you are at operating temperatures. Remove the topo of the air cleaner for verification. Quote Link to comment Share on other sites More sharing options...
george_1970_406 Posted October 24, 2011 Author Share Posted October 24, 2011 It is not using oil, and the smoke is white not cloudy but, burn your eyes strong. It has and electric choke I will look at this evening. Also the smoke is coming out of both pipes. Â George Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 24, 2011 Share Posted October 24, 2011 are you using coolant? Â I mean is the coolant level dropping? Quote Link to comment Share on other sites More sharing options...
george_1970_406 Posted October 24, 2011 Author Share Posted October 24, 2011 No coolant loss Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted October 24, 2011 Share Posted October 24, 2011 George have you checked your trans fluid lately? I've seen trans modulators fail allowing the fluid to be drawn into the intake which in turn dumps the fluid into the motor. Â If it's smoking that much can you identify the ordor? Quote Link to comment Share on other sites More sharing options...
george_1970_406 Posted October 24, 2011 Author Share Posted October 24, 2011 I think the trans is fine, less than 500 miles, but I will check the fluid anyway. I used to go through Yucipia on the way to Big Bear. Thanks for for the info. I like the thought of the choke idea.. George Quote Link to comment Share on other sites More sharing options...
Chevyss Posted October 24, 2011 Share Posted October 24, 2011 Heck George; It's old enought to smoke. LOL Quote Link to comment Share on other sites More sharing options...
