green_monte Posted December 31, 2011 Share Posted December 31, 2011 do you think this will be a good street combo and will it make 450 hp? 2 bolted mark IV 454 block bored 060 and zero decked cast oem crank Scat pro stock I beam rods SRP flattop pistons (9.0 in comp with zero decked block and my chamber size) Clevite bearings Feelpro gasket set Stock damper Scat flexplate A set of rebuild Edelbrock ovals with beehives 110 cc ZZ 502 hyd roller camshaft 050 224 in / 234 out .527 intake / .544 exhaust Morel street series lifters Lunati stamped steel rockers Edelbrock RPM Airgap intake Holley 3310 4150 750 vac carb Summit 110 gph fuelpump Rebuild GM HEI distributor Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted December 31, 2011 Share Posted December 31, 2011 I had one close but I used a lot more cam and compression, yours will be a great street engine Quote Link to comment Share on other sites More sharing options...
dbreese Posted January 1, 2012 Share Posted January 1, 2012 450 hp... Yep!!! It will also make a bunch of low end torque!! Nice street combo. David Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted January 1, 2012 Share Posted January 1, 2012 With the aluminum heads I would bump the compression a bit if possible. Nice build though. Quote Link to comment Share on other sites More sharing options...
Mom's Car Posted January 1, 2012 Share Posted January 1, 2012 With the aluminum heads I would bump the compression a bit if possible. Nice build though. Ditto Quote Link to comment Share on other sites More sharing options...
Machtuck Posted January 4, 2012 Share Posted January 4, 2012 Ditto Quote Link to comment Share on other sites More sharing options...
green_monte Posted January 4, 2012 Author Share Posted January 4, 2012 I know the compression is a bit low. maybe i will mill the heads or change them to the 100cc in the future. or shoud i change pistons? Quote Link to comment Share on other sites More sharing options...
72 LS5 Posted January 4, 2012 Share Posted January 4, 2012 With the aluminum heads I would bump the compression a bit if possible. Nice build though. I would say you could safely go up 1 full point in compression. Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted January 6, 2012 Share Posted January 6, 2012 do you think this will be a good street combo and will it make 450 hp? IT WILL MAKE AROUND 375 RWHP 2 bolted mark IV 454 block bored 060 and zero decked cast oem crank ALL THE BLOCK YOU WILL EVER NEED Scat pro stock I beam rods KEEP IT BELOW 6500 SRP flattop pistons (9.0 in comp with zero decked block and my chamber size) I SMELL NOS Clevite bearings THE STANDARD WHICH WE LIVE BY Feelpro gasket set PERFECT Stock damper GO SFI> STOCKERS WILL EXPLODE Scat flexplate NOW YOUR COOKING WITH GAS A set of rebuild Edelbrock ovals with beehives 110 cc ZZ 502 hyd roller camshaft 050 224 in / 234 out .527 intake / .544 exhaust BIGGER MAN< BIGGER Morel street series lifters WORKS Lunati stamped steel rockers RELIABLE,NUFF SAID Edelbrock RPM Airgap intake LOVE IT! Holley 3310 4150 750 vac carb WHAT? DP DUDER< DP! Summit 110 gph fuelpump PERFECT Rebuild GM HEI distributor MSD MODULE AND COIL Quote Link to comment Share on other sites More sharing options...
