Monte7071 Posted January 26, 2012 Share Posted January 26, 2012 I have a bad vacuum leak at the base of my carb anybody have a pic of the one they have used. Everybody keeps showing me the same one I have at the parts stores. Quote Link to comment Share on other sites More sharing options...
overdrive Posted January 26, 2012 Share Posted January 26, 2012 Depends on what carb you're running. Dan Quote Link to comment Share on other sites More sharing options...
Monte7071 Posted January 26, 2012 Author Share Posted January 26, 2012 The factory quadrajet I guess I should have disclosed that. Quote Link to comment Share on other sites More sharing options...
stangeba Posted January 26, 2012 Share Posted January 26, 2012 I think, the carburetor base plate gasket is different depending on what Q-jet you have. I would ensure any replacement base plate gasket matches the one that was on your car originally. I think they may add two types in a rebuild kit one with 3 or 4 holes and one with one big hole, as I remember. Is the original one missing? Bruce base gasket picture Quote Link to comment Share on other sites More sharing options...
Monte7071 Posted January 26, 2012 Author Share Posted January 26, 2012 Bruce I have the original carb the part number is 7041200. I matched the gasket with what came off of it but the car didnt run good before so maybe it was the wrong one also. I gues I will try to take the carb in and try to match one up. Quote Link to comment Share on other sites More sharing options...
Monte7071 Posted February 2, 2012 Author Share Posted February 2, 2012 I found the correct one no more vacuum leak now to replace the leaking transmission pan gasket. Quote Link to comment Share on other sites More sharing options...
stangeba Posted February 2, 2012 Share Posted February 2, 2012 Did you take a picture of it? Bruce Quote Link to comment Share on other sites More sharing options...
Monte7071 Posted February 2, 2012 Author Share Posted February 2, 2012 No I was rushing to put it on a lunch. Quote Link to comment Share on other sites More sharing options...
