Xxyyzz Posted April 5, 2012 Share Posted April 5, 2012 Got in my car when it was dark, arrived at work when it was light. Didn't notice I left my lights on... and the rest is history. So anyone installed a buzzer? How? -Mark Quote Link to comment Share on other sites More sharing options...
amsterdam84 Posted April 6, 2012 Share Posted April 6, 2012 OK I thought about this and I'm thinking it would have to be a relay that ran off the ignition wire that also ties in the door switch so that when you car is off and you open the door the buzzer should go off. I was trying to think that it would be a normally closed switch in the relay so that when your car is running and your door is open it wont buzz then. Almost sounds like you would need 2 relays. One works off the ignition wire, the other off the headlight switch. As long as you have no power on the ignition and power going to the headlights it should sound when you open the door. I would have to get back to you on the logistics of actually wiring that up. Or it may be a lot simpler than I think it is and I`m making it very compicated. In that case I am sorry. Quote Link to comment Share on other sites More sharing options...
RichG Posted April 6, 2012 Share Posted April 6, 2012 I bought a little kit at my Chevy dealer several years ago. It was $4.95 Two wires hooked up to a buzzer. Pretty simple install. One lead goes to the inst lamps fuse and the other you use a test lead to find a circuit that goes dead when IGN is turned off. Buzzer stays off if lights are on and IGN is on, when lights are on and IGN off, the buzzer sounds. Quote Link to comment Share on other sites More sharing options...
Xxyyzz Posted April 6, 2012 Author Share Posted April 6, 2012 Thanks Rich. that sounds cool, maybe i can find one on ebay or summit. If someone find a link please let me know! Mike, thanks for thinkin outside of the box for me! -Mark Quote Link to comment Share on other sites More sharing options...
montefrazer Posted April 12, 2012 Share Posted April 12, 2012 I bought a little kit at my Chevy dealer several years ago. It was $4.95 Two wires hooked up to a buzzer. Pretty simple install. One lead goes to the inst lamps fuse and the other you use a test lead to find a circuit that goes dead when IGN is turned off. Buzzer stays off if lights are on and IGN is on, when lights are on and IGN off, the buzzer sounds. Did this job myself with an old seat belt buzzer. Parts needed: buzzer, wire, two fuse taps, four crimp on ends, one wire tie, and a test light. Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 12, 2012 Share Posted April 12, 2012 I though about this part number PAC-1300 from dakota digital give you the auto on headlights like the newer cars have then you won't need to mess with the headlight switch. Quote Link to comment Share on other sites More sharing options...
