DRDIRT11 Posted August 13, 2012 Share Posted August 13, 2012 I was wondering what you guys have done with your fuel vapor canister that is mounted on radiator support. I only have one line that comes from fuel tank because I did away with lines to cylinders years ago. Any way to get rid of that canister? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 13, 2012 Share Posted August 13, 2012 plug the line unbolt it and put it on the ""collect dust" shelf Quote Link to comment Share on other sites More sharing options...
DRDIRT11 Posted August 13, 2012 Author Share Posted August 13, 2012 So it shouldnt cause a prolem? I think it was suppose to be hooked to vacume anyway so it wasnt working any way. O nly other thing i was thinkin was to put a small filter on end of 3/8 hos so it would help vent tank. What you think? Quote Link to comment Share on other sites More sharing options...
Andreas Posted August 13, 2012 Share Posted August 13, 2012 So it shouldnt cause a prolem? I think it was suppose to be hooked to vacume anyway so it wasnt working any way. O nly other thing i was thinkin was to put a small filter on end of 3/8 hos so it would help vent tank. What you think? That's what I did. Used a small carbon filter box from a motorcycle.... Fits behind the driver side inner fender out of sight Quote Link to comment Share on other sites More sharing options...
dbreese Posted August 13, 2012 Share Posted August 13, 2012 Originally Posted By: DRDIRT11 So it shouldnt cause a prolem? I think it was suppose to be hooked to vacume anyway so it wasnt working any way. O nly other thing i was thinkin was to put a small filter on end of 3/8 hos so it would help vent tank. What you think? That's what I did. Used a small carbon filter box from a motorcycle.... Fits behind the driver side inner fender out of sight Andres, Do you recall what make, model motorcycle you got the carbon filter box from? Is this something that I can go to a dealership or shop and pick up? I like the idea of hiding it behind iner fender. Thanks, David Quote Link to comment Share on other sites More sharing options...
Canuck Posted August 15, 2012 Share Posted August 15, 2012 If you do plug the line, do you need to change to a vented fuel cap like the ones the 70 Montes had? Quote Link to comment Share on other sites More sharing options...
