Its Just Me Posted March 12, 2013 Share Posted March 12, 2013 My parking lights and my dash lights all turn on when my key is in the run position. The lights are quite dim and they brighten a bit when I rev the engine. I replaced the light switch to no avail (needed to change it for other reasons though). All the lights work as they should with the key off, but I lose the ability to dim my dash (or turn off the parking & dash lights) when the key is turned on. I do not have LED lights. I have good grounds from the battery to the engine and from the battery to the front fender. The car was restored previous to me so I have no idea if a wire is crossed or connected wrong, though based on previous issues, nothing would suprise me. Could it be the key switch? Where should I start looking. Thanks Scott Quote Link to comment Share on other sites More sharing options...
Toppless72 Posted March 13, 2013 Share Posted March 13, 2013 Scott, Do you have an aftermarket radio in the car? If so, the problem could be at the radio hook up. If the radio power wire (20g yellow) is connected to the wire that powers the dial lamp (20g gray) it will reverse feed the whole parking light circuit. Here is where I would start. With the key on and the headlight switch off, start pulling fuses one by one and see when the lights go off. That will be the circuit to trace down for the problem. Quote Link to comment Share on other sites More sharing options...
Its Just Me Posted March 13, 2013 Author Share Posted March 13, 2013 Joe: I do have an aftermarket radio, but I unhooked it completely and nothing changed. I'll give your suggestion to pull fuses a try when I can get back to my car. Thanks for the help. Scott Quote Link to comment Share on other sites More sharing options...
Toppless72 Posted March 13, 2013 Share Posted March 13, 2013 Scott, Make sure if you disconnected the radio that the gray wire is not making contact with any other wire. Quote Link to comment Share on other sites More sharing options...
stangeba Posted March 13, 2013 Share Posted March 13, 2013 When I first read this, I thought of a poor or missing ground somewhere. There is a dash (I/P) ground wire that is attached to the parking brake assembly. There is a H/L switch ground. These pictures should point you to their location. Also, didn't we conclude back several months ago that the H/L switch was special for our Monte's and many replacements were missing a strap between two lug on the switch? Bruce Dash ground on parking brake H/L switch ground strap Original 71 H/L Switch Quote Link to comment Share on other sites More sharing options...
Its Just Me Posted March 23, 2013 Author Share Posted March 23, 2013 Toppless72: I was able to work on the monte a bit last night and pulled fuses out of the fuse block until the parking lights went out. The fuse that killed the parking lights was the one in the "radio" slot of the fuse block. So now I know which circuit is affecting the lights, but what is the next step? In an earlier post you made reference to a gray 20g wire and a dial lamp. Could you clarify. Is the gray wire you refer to, on the back side of the fuse block, as I don't see any gray wires on the face of the fuse block? What is a dial lamp? Sorry, I'm not too sharp on electrical issues, but I'm trying to learn. Bruce: I confirmed that I have both the ground wire connections you refer too, and I did replace the headlight switch, (with your previous assistance, thanks again). The switch needed to be replaced because the dimmer motion was shot and some lugs were loose. I was hoping that the switch replacement would solve this issue...wrong. Thanks all Scott Quote Link to comment Share on other sites More sharing options...
monte70car Posted March 23, 2013 Share Posted March 23, 2013 The dial lamp is what lights up the display of the factory radio. The grey wire should only have juice on it when your lights are on. They might have tied other items to the radio fuse. Quote Link to comment Share on other sites More sharing options...
Toppless72 Posted March 23, 2013 Share Posted March 23, 2013 Scott, As Robert has explained, the dial lamp is powered by the gray 20g. wire in the original radio. It just lights the dial so it can be seen at night. It’s controlled by the headlight switch and only receives 12 volts positive when the headlight switch is moved to the parking light mode. It remains energized when the headlight switch is moved the full headlamp mode. The issue you have is that a switched 12 volt power source is connected into your parking light circuit after your headlamp switch. Behind the instrument panel all the factory lighting for the instrumentation is via the cluster printed board or, by 20g. gray wires running to the heater control unit and in the harness to the radio. Also, if your car has a console, there will be a gray wire in the harness running to it to illuminate the shift indicator when the headlamps/parking lamps are on. Unless something else has been added, by your discovery of the radio fuse causing the lights to go off, it’s clear the yellow power wire in the original radio harness is making contact with the lighting circuit wiring. The yellow wire comes directly from the fuse panel to the radio. Nothing else should be connected to this yellow wire. The gray wire also comes from the fuse box and just behind the instrument panel it will split into three wires. One goes to the radio, one to the heater control unit and one to the harness that plugs into the back of the cluster. Your mission is to insure these wires are not contacting anything. I still believe your power wire for the radio is contacting the gray wire for the lighting circuit somewhere. Please let us know what you find out. Quote Link to comment Share on other sites More sharing options...
Its Just Me Posted March 24, 2013 Author Share Posted March 24, 2013 Score one for the good guys! Joe, you were dead on...I dug around in the mess of wires that was the connection to the aftermarket radio. What I found was, whoever installed the "new" radio, cut the original radio connector off, then proceeded to twist the gray and yellow wire together, and nicely wrapped it in e-tape. I un-wrapped and un-twisted the wire and waa-laa...no more lights with the key switch. After doing the happy dance, I clipped the yellow & gray wires back to the insulation, folded the gray wire back then wrapped them all together with e-tape. Thanks to all who have helped me with this (and other) issues. It may sound old and rehashed, but this is, by far, the best and most generous Club anyone could ever be a part of...I just wish I would have joined sooner. Thanks again! Scott Quote Link to comment Share on other sites More sharing options...
Toppless72 Posted March 24, 2013 Share Posted March 24, 2013 Scott, I'm glad you found it. Searching out those electrical gremlins is my favorite part of tinkering with these old buggies. Joe Quote Link to comment Share on other sites More sharing options...
stangeba Posted March 24, 2013 Share Posted March 24, 2013 Thanks for letting us know what it was. Quote Link to comment Share on other sites More sharing options...
