jvssmail Posted July 27, 2013 Share Posted July 27, 2013 Does anyone have a diagram or pic of how the radiator support goes in. Took mine out a year ago and just want to be sure before I put new one in. Quote Link to comment Share on other sites More sharing options...
Joe Vega Posted August 1, 2013 Share Posted August 1, 2013 The part with the ledge on the bottom will face the motor, it supports the radiator. Then you should be good from there. Quote Link to comment Share on other sites More sharing options...
jvssmail Posted August 14, 2013 Author Share Posted August 14, 2013 have most of it back together, doing a little at a time so I get it all correct. Just wasnt sure about the bushings that attach it to the frame rails. The originals were rusted up pretty badly so I had to replace the whole assembly. I purchased a new poly bushing kit for the car as well a bolt kit but I believe there are still some parts I need, looks like there should be some type of sleeve or insert that keeps everything tight. Also there were no washers in the bolt kit that seem to be correct in size especially for the top of the bushing when I tighten it the upper poly seems incorrect so Im thinking either a larger washer on top or a sleeve inside . Trying to find a diagram but so far have not been able to. Quote Link to comment Share on other sites More sharing options...
bigtankjones Posted August 15, 2013 Share Posted August 15, 2013 I replaced all my body bushing with stock replacement bushings. The kit came with all new washers and bolts. You will definitely need washers Quote Link to comment Share on other sites More sharing options...
footballubet Posted August 15, 2013 Share Posted August 15, 2013 The body mounts should look something like this. (Not a Monte body mount picture). They have the big washer and bushing built together and another big washer for the bolt side. Quote Link to comment Share on other sites More sharing options...
jvssmail Posted August 16, 2013 Author Share Posted August 16, 2013 ok i see what im missing , the bushing with the washer attached. thanks for the pic. Quote Link to comment Share on other sites More sharing options...
Outrider70 Posted August 18, 2013 Share Posted August 18, 2013 Was it an Energy poly kit? Because mine was and there were no insert collars for the core support with it, or washers. [edit] Nevermind, just looked at a pic of the kit and realized that they are still in Dads garage! I wasn't there when he did the rest of the body mounts, and he's not around to ask anymore...so most of this car has been a lot like, well, finishing someone elses project car that you didn't get to take apart! First was then... then... Quote Link to comment Share on other sites More sharing options...
