71 monte project Posted August 7, 2013 Share Posted August 7, 2013 i know its something in the front end steering i just cant pin point it... anybody else had this problem? should i consider a steering rebuild kit? Quote Link to comment Share on other sites More sharing options...
dbreese Posted August 7, 2013 Share Posted August 7, 2013 Could be ball joints, tie rod ends. center link or idler arm. With the vehicle running get up underneath the front end and have a helper rock the steering wheel back and forth quickly. Look for lost motion at the center link, tie rod ends and idler arm. If all looks jack one side underneath the front control arm and use a pry bar or large screw driver and lift up on the tire. If the ball joints are bad you will hear a clunking noise and see the move spindle move up. just a few suggestions. David Quote Link to comment Share on other sites More sharing options...
Andreas Posted August 7, 2013 Share Posted August 7, 2013 As Dave said it's more likely a suspension problem than steering. Also, I had a loose brake caliper once which made a clunk sound.... Quote Link to comment Share on other sites More sharing options...
wallaby Posted August 8, 2013 Share Posted August 8, 2013 More places to look: Check the upper control arms where they enter the engine compartment, see if they are moving. I had a stack of alignment shims fall out and gave a bunch of slop in the bolts that are supposed to hold them firm against the frame. Here is a picture: check for a gap here where they are showing shims under his thumb, there is a front AND rear bolt where shins might be. Also look at the bushings at the ends shown in the picture.. right where his hand is cupped underneath. There should be little/no movement when you steer back & forth. Quote Link to comment Share on other sites More sharing options...
71 monte project Posted August 9, 2013 Author Share Posted August 9, 2013 thanks for all the feedback guys im gonna do some investigating this weekend Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted August 9, 2013 Share Posted August 9, 2013 More places to look: Check the upper control arms where they enter the engine compartment, see if they are moving. I had a stack of alignment shims fall out and gave a bunch of slop in the bolts that are supposed to hold them firm against the frame. Here is a picture: check for a gap here where they are showing shims under his thumb, there is a front AND rear bolt where shins might be. Also look at the bushings at the ends shown in the picture.. right where his hand is cupped underneath. There should be little/no movement when you steer back & forth. I had the back shim pack fall out of mine a couple years ago I was thinking bushings but it wasnt. Look it over good you should be able to find it. Quote Link to comment Share on other sites More sharing options...
71 monte project Posted August 11, 2013 Author Share Posted August 11, 2013 i took a look at it an found that the bushings on the passanger upper control arm was rotted out.. Quote Link to comment Share on other sites More sharing options...
71 monte project Posted August 12, 2013 Author Share Posted August 12, 2013 i replaced the bushings today an the sound is gone!! thanks for the info guys Quote Link to comment Share on other sites More sharing options...
