lowcadillac Posted April 11, 2018 Share Posted April 11, 2018 Hi all, after a bit of advice. My washer pump isn’t working and someone’s screwed an after market one to the wheel arch liner,poked the wires into the original motors plug and it looks rubbish. I’ve fitted a new diaphragm kit and still no joy so think it’s the seal/ o ring on the piston inside the pump. Can I get a replacement from any where do you know? Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted April 11, 2018 Share Posted April 11, 2018 If the wiper washer pump is dead and won't pump when prompted, you need a new washer pump. But first offer more info on what does/doesn't happen when you try to use squirters. Sometimes if hoses are dry and no water in the pump, pump needs primed with water. Lack of water may be your problem. If ordering a new washer pump, make sure it is the correct one for your vehicle. Use your search function or wait to see if anyone can provide you a part number based on year of your car. Some have park and others don't as an example. If you have an OHM Meter, you can check resistance and also if getting power to the pump. Here is some info I just located......................................................... There are 2 styles of wiper washer pumps. One #DA90228 comes with circuit board(s) while to other is a Manual Pump? Note: For 1970-1972 Monte Carlo without concealed wipers, please see Part # DA90228. http://www.dixierestorationdepot.com/Product/Search.aspx Doug Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted April 12, 2018 Share Posted April 12, 2018 I had to replace my pump a year ago. Mine quit working and I wanted to rebuild it but found the plunger broken inside and could not rebuild mine. I was able to purchase one from advance auto parts. I just put in the year of my Monte Carlo and purchased the one that came up for my year Monte. It doesn't look completely original but it fit perfectly. rob Quote Link to comment Share on other sites More sharing options...
lowcadillac Posted April 12, 2018 Author Share Posted April 12, 2018 Mechanically the pump works,you can here it clicking when you press the washer switch but it won’t provide the necessary suction to pump the water. I think the o ring on the piston much be at fault but don’t know if you can get a replacement. Thanks for the part numbers,that may be my only option,however I will see if I can prime the pump somehow. Whatever happens the universal one on the wheel arch has got to go. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted April 12, 2018 Share Posted April 12, 2018 Pull one of squirter hoses and see if it's dry on the end, if so you aren't getting water to the squirters which once primed still don't work you need a windshield washer Pump. When mine went out it was the o-ring(s) that allowed water to spray everywhere but onto the windows and could be seen when pump ran. I tried the o-ring kit but did not seal. Doug Quote Link to comment Share on other sites More sharing options...
overdrive Posted April 14, 2018 Share Posted April 14, 2018 The Parts Place has new pump assemblies that are the perfect replacement. Dan Quote Link to comment Share on other sites More sharing options...
lowcadillac Posted May 9, 2018 Author Share Posted May 9, 2018 Well I fitted a Delco Remy pump from RockAuto. Not original I know but to the untrained eye it looks good. And I’ve now got rid of the horrible one screwed to the inner wheel arch cover along with its ugly wiring and droopy tubing. I’ll keep the original in case I ever find a new seal for the piston one day. Quote Link to comment Share on other sites More sharing options...
