Wiring Diagram
Shawn63
"I am removing my MSD"
What are you replacing it with?
If you go with a standard GM HEI you will need to run full 12 volts. If you go back to Points, you will need the resistor.
Bruce
Hi Bruce
When I got the car it had the original point system,and an MSD box.
I have heard a loud buzz,humm noise when the car warmed up.
We first thought it was the transmission,but it turns out to be the MSD box.
I would like to disconnect it and let the original system work.
I am thinking of a Pertronix or a HEI at some point when budget allows of course.
Shawn
Shawn
My two cents on anything "REBUILT" is have your own rebuilt by a small local shop or get a used one from the "Pick A Part" AKA Junk Yard and clean it up. Many many rebuilt items are not done correctly.
Bruce
