vacavillebob Posted December 3, 2013 Share Posted December 3, 2013 Hi everyone: Every time there is something I know has been shown on this site, I go to search and type in what it is I am looking for but to date I have never been able to find a single item yet. This time I know there is a discription of how to remove the dash. But I can not find it in search. I am trying to find out how much I need to remove to replace the clock with a tach and to replace the lights with LED's. There are about 3 lights I can not get to even if I drop my steering column. So I need to pull the dash. Can anyone tell me where this discription is on pulling the dash. Thank you, Bob Quote Link to comment Share on other sites More sharing options...
Rock Posted December 3, 2013 Share Posted December 3, 2013 http://www.firstgenmc.com/ubbthreads/ubbthreads.php?ubb=postlist&Board=28&page=1 Quote Link to comment Share on other sites More sharing options...
vacavillebob Posted December 3, 2013 Author Share Posted December 3, 2013 Thank you Rock: I don't know how you guys can find this stuff so easy when I can never find them. Thank you Quote Link to comment Share on other sites More sharing options...
Rock Posted December 3, 2013 Share Posted December 3, 2013 No problem buddy!! Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted December 3, 2013 Share Posted December 3, 2013 I think this is the Post your looking for Bob. Did mine a couple years ago for similar reasons. A good opportunity to refresh/change gauge lens, circuit board along with your original goals. My 1st time removing and will advise, take lots of pics of procedures removing, they will come in handy when re installing. I also re sealed my vent connections as they were badly deteriorated. Don't forget to remove radio window antenna also if you have one. Dash Removal Best of luck...... Doug Quote Link to comment Share on other sites More sharing options...
Andreas Posted December 3, 2013 Share Posted December 3, 2013 Hi everyone: Every time there is something I know has been shown on this site, I go to search and type in what it is I am looking for but to date I have never been able to find a single item yet. This time I know there is a discription of how to remove the dash. But I can not find it in search. I am trying to find out how much I need to remove to replace the clock with a tach and to replace the lights with LED's. There are about 3 lights I can not get to even if I drop my steering column. So I need to pull the dash. Can anyone tell me where this discription is on pulling the dash. Thank you, Bob Bob, you are using the Advanced Search function and you are setting the Date Range to 'Newer that 8 years', correct? If not, you will only search the posts from last week... Quote Link to comment Share on other sites More sharing options...
502ci Posted December 4, 2013 Share Posted December 4, 2013 Bob, you are using the Advanced Search function and you are setting the Date Range to 'Newer that 8 years', correct? If not, you will only search the posts from last week... Exactly, the most common mistake. I always us the advance search and zero out the "Newer than" section and fill in the "Older than" section with a date just prior to when I think it might be. It also helps to fill in the "Display Name Search" with a person's name who may have been in that thread. Quote Link to comment Share on other sites More sharing options...
vacavillebob Posted December 6, 2013 Author Share Posted December 6, 2013 Thank you everyone. I was not aware of the advance search. I would just click the search box and type in what I was searching for. I will correct that from now on. Quote Link to comment Share on other sites More sharing options...
vince Posted December 11, 2013 Share Posted December 11, 2013 nice post!! I was having the same problem searching. The newer then /older then thing had me all kerbobbled. Quote Link to comment Share on other sites More sharing options...
