laurent Posted January 30, 2007 Share Posted January 30, 2007 Hi, I bought an autometer mechanical water temperature gauge and i don't know where to put the temperature sensor (with the 1/2" npt mounting nut) on the engine. Can you help me please? thank you. Link to comment Share on other sites More sharing options...
footballubet Posted January 30, 2007 Share Posted January 30, 2007 Look for plugs on the heads. You can remove one of those for the sensor. Some intakes have extra threaded holes in them also. Link to comment Share on other sites More sharing options...
laurent Posted January 30, 2007 Author Share Posted January 30, 2007 Do you have an idea of the side of the engine please because the only one plug i saw is not the good? I have a '72 Monte with a 350 engine Link to comment Share on other sites More sharing options...
Guest Posted January 30, 2007 Share Posted January 30, 2007 If you use the one on the head the temperature will run about 10° hotter then if you were able to find a plug on the intake. I think if you had to you can get aftermarket thermostat housing with a plug in it; again I am not sure but it might be worth checking on. Link to comment Share on other sites More sharing options...
Mike 57 Posted January 30, 2007 Share Posted January 30, 2007 There should be a 1/2 inch pipe plug with a 3/8 square drive recess or a electric temp sensor between cylinders 1 & 3 and a plug between cylinders 6 & 8 or like on the previous post go into the intake. Link to comment Share on other sites More sharing options...
bigscaht Posted January 31, 2007 Share Posted January 31, 2007 its on the passenger side and if its the original plug on the original engine..its gonna be hard as hell to get out. Get and aftermarket intake, there will be a plug on ther to use!!! Link to comment Share on other sites More sharing options...
laurent Posted January 31, 2007 Author Share Posted January 31, 2007 Thank you for your answers but i prefer to put pictures to be sure. first: on the driver side between cylinders 1 & 3 but i think it's for oil pressure ?? second: on the passenger side between cylinders 6 & 8. Maybe a possibility but i think it's for oil too. Thank you Bigscaht,Mike,trunklid and footballubet for your help. Link to comment Share on other sites More sharing options...
footballubet Posted January 31, 2007 Share Posted January 31, 2007 Those are both for coolant. Use the one with the sending unit already there. That one should be easier to remove. Good luck. Any problems pm me. Link to comment Share on other sites More sharing options...
laurent Posted January 31, 2007 Author Share Posted January 31, 2007 Great, i'm happy, it's works. Thanks, thanks, thanks. Link to comment Share on other sites More sharing options...
wallaby Posted February 1, 2007 Share Posted February 1, 2007 And just so you know, the oil pressure sender is in the back of the engine near the distributor. Link to comment Share on other sites More sharing options...
502ci Posted February 1, 2007 Share Posted February 1, 2007 And just so you know, the oil pressure sender is in the back of the engine near the distributor. Which is no fun to add on a big block "after" the motor is installed...I had to use a mirror... Link to comment Share on other sites More sharing options...
laurent Posted February 1, 2007 Author Share Posted February 1, 2007 And just so you know, the oil pressure sender is in the back of the engine near the distributor. Ok,i take good note of this. Maybe i will put an oil pressure gauge. Thank you Link to comment Share on other sites More sharing options...
kc8oye Posted February 17, 2007 Share Posted February 17, 2007 just as a note.. IMHO.. the HEAD is the ONLY Place a temp sensor should be... who cares about the water temp in the intake manifold? I'm more concerned with where my heads are at.. and if my head gaskets are in danger yet i've discovered when you nearly run out of coolant.. the heads get very hot from the lack of coolant flow.. adn the intake manifold temp sensor doesn't always see that. Link to comment Share on other sites More sharing options...
wallaby Posted February 17, 2007 Share Posted February 17, 2007 Yea, but the temp sender in the head can also read high because it is so close to the exhaust. It's a toss-up. I kept my original sender so my light on the dash would still work, and added a mechanical sender to the intake near the thermostat. I figure I get a good average reading there. I snooped through the self-serve wrecking yard and found a suitible coolant overflow bottle, and it even has a sender in it to turn on a dash light when coolant gets low. I know it isn't a perfect system, but it's a step in the right direction. Link to comment Share on other sites More sharing options...
kc8oye Posted February 17, 2007 Share Posted February 17, 2007 my mech. gauge sender is in my driver's side head.. and my light is connected to a sender in the passenger side head.. only problem is.. that's a gauge sender in the passenger head!!! (it was there when I got the engine, single wire hookup, I thought it was a switch) but the hotter the engine gets, the brighter the temp light glows! LOL next time I drain the cooling system I'm gonna swap it for a switch :> Link to comment Share on other sites More sharing options...
