pocobill7t1 Posted January 30, 2014 Share Posted January 30, 2014 Ok guys and gals, on my 71 I found courtesy lights on pass and driver sides. only wires coming out of sockets are a white wire(looks like it goes to base of lamp) and then a orange. Which wire or wires go to jamp switch on booth sides? HELP Quote Link to comment Share on other sites More sharing options...
CKZ03 Posted January 30, 2014 Share Posted January 30, 2014 White Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 30, 2014 Share Posted January 30, 2014 white  orange is 12v constant, white is ground controlled by the door switches Quote Link to comment Share on other sites More sharing options...
Murphy Posted January 30, 2014 Share Posted January 30, 2014 White wire goes to the door switch, orange should have 12volts. When the door is open, it completes the circuit when the switch plunger pops out making the lights come on. Quote Link to comment Share on other sites More sharing options...
footballubet Posted January 30, 2014 Share Posted January 30, 2014 I would have to say....white wire. Quote Link to comment Share on other sites More sharing options...
pocobill7t1 Posted January 30, 2014 Author Share Posted January 30, 2014 OK it is working, one more question when I open the drivers door the floor courtesy light goes on, when I open the pass door the floor courtesy light goes on is this right? Quote Link to comment Share on other sites More sharing options...
Murphy Posted January 30, 2014 Share Posted January 30, 2014 Opening either door should allow for all 3 lights to illuminate (2 under the dash & 1 dome light)Also, twisting the light switch on the dash should produce the same results when the doors are closed. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 31, 2014 Share Posted January 31, 2014 Quote Link to comment Share on other sites More sharing options...
pocobill7t1 Posted January 31, 2014 Author Share Posted January 31, 2014 i have got it all fixed now, I was playing around with the wiring and had it set up so when one door is open that side courtesy light would light up and no dome light. it looks good at night when just the floor lights come on and you manually have to turn the dome light on if needed. Now open either door and all three come on. Had to re wire to all switches as previous owners cut pieces out and it was hell tracing them. thanks for your help once again I am a happy boy... Quote Link to comment Share on other sites More sharing options...
MCfan Posted January 31, 2014 Share Posted January 31, 2014 If you have buckets and a console, the light on the back of the console should also come on to illuminate the rear floor. The bulb was burned out on mine and I didn't even know it was there until I removed the console to install new carpet. Works fine now. Quote Link to comment Share on other sites More sharing options...
