71MonteCarloMD Posted November 14, 2014 Share Posted November 14, 2014 I noticed my TH350 have issue with reverse when starting up, going off real slow or nothing at beginning. After driving around, no issue with reverse, the transmission fluid level is fine, what else would cause the reverse not working very well at cold start? Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted November 14, 2014 Share Posted November 14, 2014 You will also probably notice it starting out in low soon, most likely low reverse clutch pack going bad probably due to the seal going or gone bad in low reverse piston. Sorry looks like overhaul in in your not to distant future. Look inside the trans pan you'll probably see some silver stuff in the pan. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted November 14, 2014 Share Posted November 14, 2014 you can try a filter change, I've had luck with that on a TH400, might buy you a little more time Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted November 15, 2014 Author Share Posted November 15, 2014 How much would it cost for someone to rebuild it? And I am a DIYer, would I be able to rebuild it myself? Quote Link to comment Share on other sites More sharing options...
footballubet Posted November 15, 2014 Share Posted November 15, 2014 They aren't too bad to rebuild. But you will need a couple specialty tools. Most any shop that rebuilds trans will give a warranty also. Do some checking around at your local shops on prices if you drop it off for them to rebuild. Might just be worth the price without the headaches. Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted November 15, 2014 Share Posted November 15, 2014 See if you can find a tyranny guy that does stuff on the side. They aren't hard but there are some special tools as said Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted November 15, 2014 Author Share Posted November 15, 2014 Thanks guys, how much should it cost to rebuild? Quote Link to comment Share on other sites More sharing options...
BigdaddyT Posted November 15, 2014 Share Posted November 15, 2014 The last th350 I had built cost $325 with a new converter. I swapped it out myself. Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted November 26, 2014 Share Posted November 26, 2014 Was just wondering how you made out with this tranny. Have you done anything yet with it ? Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted November 27, 2014 Author Share Posted November 27, 2014 Not doing anything right now as I'm working on rust repairs and focusing on painting. May change filter as Sam suggested. After body work, plan is to have it rebuild by local transmission shop maybe in 2016. Quote Link to comment Share on other sites More sharing options...
