V8Freak Posted December 5, 2014 Share Posted December 5, 2014 So anybody else have a lot of trouble thing too get the high pressure power steering hose? None of the parts places can get me one that fits properly. And the ones they are sending don't look anything like the original on either of my two 70 Montes. I have looked online and the ones I'm seeing for my car look like the ones the jobers are sending me but again they do not look like the originals Help would be appreciated lol Quote Link to comment Share on other sites More sharing options...
MC-71 Posted December 5, 2014 Share Posted December 5, 2014 Are you sure the one in your Monte is original. Do you have a assembly manual? that will show you the picture and the GM part number. Quote Link to comment Share on other sites More sharing options...
V8Freak Posted December 5, 2014 Author Share Posted December 5, 2014 Yes I do actually, I will look, the one on my car sure seems too be perfect the ones I'm getting don't seem too fit due too the way the steel ends of the lines are bent Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted December 5, 2014 Share Posted December 5, 2014 I sent all the aftermarket ones back and used my original Quote Link to comment Share on other sites More sharing options...
V8Freak Posted December 5, 2014 Author Share Posted December 5, 2014 Problem is I can't use my original anymore, too far gone, did you run into the same problem? Quote Link to comment Share on other sites More sharing options...
V8Freak Posted December 5, 2014 Author Share Posted December 5, 2014 How do I ad a pic? Quote Link to comment Share on other sites More sharing options...
lastss Posted December 5, 2014 Share Posted December 5, 2014 Most city's have a hydraulic hose place that will make you anew one from & using your orginal ends. Bob Quote Link to comment Share on other sites More sharing options...
MCfan Posted December 5, 2014 Share Posted December 5, 2014 I had exactly the same problem ... whatever data base the parts houses use, they all seem to be wrong on this particular part. The part they gave me first was not even close so I looked up the part numbers in my '70 GM Assembly Manual and took them to my local Advance Auto Parts store. As soon as they had the correct factory PNs, they were able to order the correct hoses. My Assembly Manual lists the following part numbers: For small block: 3972655 Inlet hose assembly 3773685 Outlet hose assembly For big block: 3972653 Inlet hose assembly 3931898 Outlet hose assembly These four PNs are called out specifically for Model 13857 (Monte Carlo) Regarding how to post pictures on this new system, I have only found one way so far. When you are replying to a post, go down to the lower right and click on the box that says "More Reply Options". Now, if you scroll all the way down below the text entry box you will see a section called "Attach Files". Just click on "Browse" to search the photo files on your computer and select the photo you want to include in your post. Now click on "Attach This File" and it will be imported directly as a thumbnail photo. If it is what you want, be sure to click on the box "Add to Post" so it will append that file below your text as a thumbnail. You can then repeat that process to add other photos in sequence. When a reader of your post clicks on any of the thumbnail photos, they will expand to full size for easier viewing. There must be a way to include full-sized photos inline with your text, but I haven't figured it out yet. Good luck. 1 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted December 5, 2014 Share Posted December 5, 2014 I got mine for my 71 at advanced auto parts fit just fine. Quote Link to comment Share on other sites More sharing options...
V8Freak Posted December 5, 2014 Author Share Posted December 5, 2014 Thanks you guys! Your always very helpful! I'll do some digging this weekend with the numbers you gave me Dennis, hopefully one of them is the right one, I will keep you posted Quote Link to comment Share on other sites More sharing options...
V8Freak Posted December 19, 2014 Author Share Posted December 19, 2014 Did you guys find the new ones a little shorter then original? Finally found one with right connections just not exactly like original, instead of wrapping around the steering box it goes over the top Quote Link to comment Share on other sites More sharing options...
MCfan Posted December 19, 2014 Share Posted December 19, 2014 Glad you found one that would at least bolt up. I found the receipt for the one I finally got to work from Advance Auto Parts. Their part number was 70255 and they reference another number of 3865533 but that doesn't match any original GM part number from the Assembly Manual. If I understand your "over the top" comment, maybe mine is the same (see photo below), but it works just fine. Quote Link to comment Share on other sites More sharing options...
V8Freak Posted December 19, 2014 Author Share Posted December 19, 2014 No mines shorter, goes over the middle of that top cover with the 4 bolts on it, not a big deal it will do what it has too. We don't have an advanced auto parts in Ontario I think out partsource would be the equivalent, do you know what brand made that hose? Mine is from Edelmann Quote Link to comment Share on other sites More sharing options...
gprimm Posted December 23, 2014 Share Posted December 23, 2014 Got mine from Advance Auto. Perfect match and fit. I always buy on-line and pick up at the store. Always look up Advance Auto discount codes and usually save 30%. Quote Link to comment Share on other sites More sharing options...
Grizzly1911 Posted February 28, 2015 Share Posted February 28, 2015 My locale O'reilly has a hydrollic shop and the offered to make me a new one if I brought in my old one. Don't know if you have access to something like that. Quote Link to comment Share on other sites More sharing options...
