MI_Custumz Posted June 24, 2015 Share Posted June 24, 2015 I have slow turn signals. I am thinkig it's the flasher. I haven't gotten to replacing it yet, too much else going on. Would this flasher work? It says electro-mechanical turn signal flasher. Also, is there a seperate flasher for the hazards on the 70 Monte or is it an all in one? http://www.autozone.com/electrical-and-lighting/hazard-warning-flasher/novita-hazard-warning-flasher/69839_132997_7281/ Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted June 24, 2015 Share Posted June 24, 2015 Yes that is the one, there is a seprate flasher for the 4 ways its on the fuse block. Quote Link to comment Share on other sites More sharing options...
stangeba Posted June 24, 2015 Share Posted June 24, 2015 Some of the bulbs may not be working, poor grounds or the flasher is wrong, there are 2, 3 and 4 bulb flashers. This is also why there is a different 4 way flasher because they draw more current and would flash too quickly if you used a regular flasher. When I had a trailer hooked up, I swapped out the t/s flasher with the 4 way flasher so I didn't have to purchase a new one. Funny you mention this, my right t/s is slower than my left. I assume the rt ground is poorer than the left but have never been able to (haven't tried very hard) correct it. I bought replacement bulbs one time (China) and had to throw them all out because the base was smaller and the bulb was too loose in the socket causing intermittent outages. Bruce Quote Link to comment Share on other sites More sharing options...
MI_Custumz Posted June 24, 2015 Author Share Posted June 24, 2015 I only saw that one, but didn't look real hard. That one was at the top of the fuse block on the left side I think. I am at work and can't recall what I saw, was a quick peek. Is there more than one on the fuse block? If not, where is the second one? Quote Link to comment Share on other sites More sharing options...
stangeba Posted June 24, 2015 Share Posted June 24, 2015 No, only the 4 way flasher is in the fuse block. The regular T/S flasher came from the factory clipped into a half circle clip attached to the steering column. After 40+ years it is probably just hanging near the steering column. Bruce Quote Link to comment Share on other sites More sharing options...
stangeba Posted June 24, 2015 Share Posted June 24, 2015 4 Way in fuse panel link: https://picasaweb.google.com/lh/photo/wxF5awbNxXM92ozZxwrw3NMTjNZETYmyPJy0liipFm0?feat=directlink near str column: https://picasaweb.google.com/lh/photo/WBCq9ps8rpBrAgxEypf-0dMTjNZETYmyPJy0liipFm0?feat=directlink Bruce Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted June 24, 2015 Share Posted June 24, 2015 Am curious how fast should it flash in between? Quote Link to comment Share on other sites More sharing options...
stangeba Posted June 24, 2015 Share Posted June 24, 2015 I read between 50 and 100 times per min. When I swap out my 4 way flasher with the std flasher it blinks very very slowly, no load to heat up the coil inside the flasher. When I added my trailer with out swapping the flasher it was very very fast. Did it change (what did you do, change bulbs) or has it always been this way? Bruce Quote Link to comment Share on other sites More sharing options...
MI_Custumz Posted June 25, 2015 Author Share Posted June 25, 2015 Thanks for the pics. Looks like it's the same flasher, visually at least. Now I just have to get under there and look deeper. I did a quick look and nothing like that hanging down. May have to trace the wires to find it. Quote Link to comment Share on other sites More sharing options...
stangeba Posted June 25, 2015 Share Posted June 25, 2015 Try looking while it is flashing, the clicking may help guide you to it. They attach the flasher to something so it amplifies the ticking sound. If left hanging, it isn't as loud. Good luck. I assume you checked that all the bulbs were flashing by running the 4 way flashers and walking around the vehicle to see them? Quote Link to comment Share on other sites More sharing options...
MI_Custumz Posted June 25, 2015 Author Share Posted June 25, 2015 I didn't check by walking around. I had it in the garage and turned on the 4 ways. I could see the reflection on the door and wall. Didn't look for the side marker lights. Do they flash? Didn't ever think of that. If a bulb is out, they flash faster. Had a front marker light out and it flashed faster. I think I may have located the flasher. It's yellow and mounted with a screw and bracket somehow. I didn't have time to take it apart this morning, but did locate it. Quote Link to comment Share on other sites More sharing options...
stangeba Posted June 25, 2015 Share Posted June 25, 2015 Just checked my 71, all work except both rear side markers with 4 way on, do not work, OK with T/S. 4 way flashers on: Dash: Left and Right both working Front: 1 of 1 bulb Left ft, 1 of 1 bulb right ft, 1 of 1 bulb left ft side 1 of 1 bulb right ft side marker Rear: 2 of 2 bulbs left rear, 2 of 2 bulbs right rear, 0 of 1 bulb left rear side marker 0 of 1 bulb right rear side marker Left Turn signal test: Left dash working Front: 1 of 1 bulb left ft, 1 of 1 bulb left ft side marker Rear: 2 of 2 bulbs left rear, 1 of 1 bulb left rear side marker Right Turn Signal test: Right dash working Front: 1 of 1 bulb right ft, 1 of 1 bulb right ft side marker Rear: 2 of 2 bulbs right rear, 1 of 1 bulb right rear side marker Quote Link to comment Share on other sites More sharing options...
MI_Custumz Posted June 27, 2015 Author Share Posted June 27, 2015 Checked mine last night. Turn signals: Front, rear, and dash blink Hazards: Front, rear, and dash blink Side marker lights don't blink, they are on when the running or headlights are on. Quote Link to comment Share on other sites More sharing options...
stangeba Posted June 27, 2015 Share Posted June 27, 2015 I haven't looked but do the ft side marker bulbs have one or two elements? For that matter, what about the rear? I think they only have one, I should check but it's raining. I also have a tilt column / T/S from a different, unknown car and unknown year. Bruce Quote Link to comment Share on other sites More sharing options...
