72-CLASSIC_RIDE Posted February 21, 2016 Share Posted February 21, 2016 Was cleaning up a 72 Grill I had stored and after removing the plastic lens, I found one og the gaskets had been deformed and unusable. Figured I would start preparing the Portland 2016 Swap meet. Are these gaskets reproduced or is the Paint Seal Kits found on eBAY simply replacement gaskets for those locations described? Doug Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted February 21, 2016 Author Share Posted February 21, 2016 Oops! Forgot about the aftermarket front window stainless trim set. Any have experience with this trim? Is it manufactured by same supplier and sold through different classic parts venues?? Thinking about replacing these at some point in the past, whoever tried buffing out with power tool (s) burnt areas of the stainless and can't be buffed out. Doug Link to comment Share on other sites More sharing options...
overdrive Posted February 22, 2016 Share Posted February 22, 2016 The stainless burns can be sanded and then buffed to look better than new. The new trim I've seen is aluminum, not stainless. Dan Link to comment Share on other sites More sharing options...
Jared Richey Posted February 23, 2016 Share Posted February 23, 2016 Yes stay away from reproduction window trim Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted February 23, 2016 Author Share Posted February 23, 2016 The stainless burns can be sanded and then buffed to look better than new. The new trim I've seen is aluminum, not stainless. Dan Scratches are pretty deep Dan.and the Repop Trim is Aluminum? Okay, that explains a couple of things..... Thanks Jared, I will stay away from the repop trim. Doug Link to comment Share on other sites More sharing options...
Jared Richey Posted February 25, 2016 Share Posted February 25, 2016 I believe the parts place offers the gaskets Link to comment Share on other sites More sharing options...
