Aaronz28 Posted March 22, 2016 Share Posted March 22, 2016 My SS454 air cleaner was refinished previously in a flat black.... is that correct? or should it be gloss? or semi?and as long as I'm asking - pulleys? brackets? gloss? semi? for original accuracy Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted March 22, 2016 Share Posted March 22, 2016 Not sure about the pulley's but I think both the air cleaner and brackets would be simi-gloss. rob Quote Link to comment Share on other sites More sharing options...
stangeba Posted March 22, 2016 Share Posted March 22, 2016 Semi gloss. Long answer, I'm chatty today....... Back in the day, GM used a product DuPont called "black dip". It was a primer that you dipped parts into, then baked them at 400 F, for 1/2 hour. This was the same product the body was dipped into prior to the invention by FORD of ELPO aka Electro deposition Primer also called E-Coat PPG then purchased the rights from FORD and they really sold the heck out of it. The gloss level (IMO) was closer to semi gloss but the industry had very specific testing procedures and specs for the actual gloss level measured at a 20 degree or 60 degree angle with the gloss meter based on high or low gloss. When restoring my 71, I worked at DuPont automotive finishes, Troy Michigan laboratory, where I had free access to black dip primer. I dipped everything I could and it held help up very well. When it came to the air cleaner, I could NOT bake the vacuum control dash pots because the rubber inside would melt @ 400 F. so I went super high gloss IMRON black and love the look. You may have noticed, I added a second air inlet on the driver side in 1971 after my brother in-law brought one home for me from the Warren tech center where he was a power train engineer at Chevrolet. Since I don't have A/C, it fit great. I blocked off the bottom inlet where the heat tube would have gone and tee'e into the vacuum hose. Today sadly they both leak so they are unplugged at the carb. Bruce 1 Quote Link to comment Share on other sites More sharing options...
lastss Posted March 22, 2016 Share Posted March 22, 2016 10 to 20% gloss is correct. Quote Link to comment Share on other sites More sharing options...
502ci Posted March 22, 2016 Share Posted March 22, 2016 I saved this a while back. I know it is a little more info than you actually for and it does not include your original answer but I see people have already helped... Underhood Detailing: Frame and upper/lower control arms and upper shafts = semi-gloss black Front coil springs = gloss black or natural (better detail contrast) Firewall, inner fenders, radiator support = semi-gloss black Radiator and fan = gloss black Fan clutch = natural aluminum Radiator shroud = natural black plastic or gloss black Steering box = natural cast iron gray Steering linkage = natural steel Front sway bar = natural cast iron gray Heater or AC housing = semigloss black Hood hinges, latch, catch and springs = gray phosphate plated Brackets and steel pulleys = semi-gloss or gloss black (gloss gives more detail contrast) Cast iron pulleys = natural cast iron Master cylinder = natural cast iron (some use gloss black) Brake booster = gold cadmium plated (master cylinder lid also) Windshield wiper motor = gloss black Alternator = natural aluminum Power steering pump = gloss black AC compressor = semi-gloss black Steering column shaft = natural steel Horns = gloss black Coil = gloss black Voltage regulator = gloss black Distributor = natural aluminum with gloss black cap Fuel and brake lines = natural steel Undercarriage Details:Transmission = natural aluminum Bellhousing = natural aluminum Transmission support = semi-gloss black Driveshaft = natural steel Rear axle = semi-gloss black Rear swaybar = semi-gloss black Rear coil springs = gloss black Rear control arms = semi-gloss black Gas tank = natural steel (shiny) Gas tank straps = gloss black Parking brake cables = natural steel 2 Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted March 25, 2016 Share Posted March 25, 2016 Great info! Quote Link to comment Share on other sites More sharing options...
